91 ex wagon---94 sohc vtec i need your help.
Old May 12, 2007 | 04:51 PM
wardcrx's Avatar
Default 91 ex wagon---94 sohc vtec i need your help.
The swap is done. F22b1 in my wagon. The p0h ecu(vtec) that came with the engine made it skip at idle but fine during revving. The stock pt6 is what i have it runs fine, but as you can assume its slow as ***** with no vtec. Its said that you can wire a pt6 to have vtec. Can any of you guys help me. If you know of a way to use a vtec ecu or prefferably wire the pt6. Thanks guys.
Old May 12, 2007 | 06:05 PM
wardcrx's Avatar
Default Re: 91 ex wagon---94 sohc vtec i need your help. (wardcrx)
helllllllllllllllllllllllllllllllllllll p me please??
Old May 12, 2007 | 07:36 PM
vtecaccordf22b1's Avatar
i did the same swap in my 92 accord ex you got to use a p0a it only came in 94-95 accord ex i got mine from junkyard
Old May 24, 2007 | 05:25 PM
wardcrx's Avatar
Default Re: 91 ex wagon---94 sohc vtec i need your help. (vtecaccordf22b1)
Still no idea whats wrong here guys. im using the stock wagon harness with the poh ecu that came out of the same car as the engine did.
Old May 25, 2007 | 07:21 AM
zerocps's Avatar
wouldn't you have run a wire for vtec to the ECU ? just a guess
Metalzone
Honda Civic (2001 - 2005)
16
Aug 3, 2015 12:04 PM
hondaman1992
Dec 16, 2011 12:07 PM
EgK2o09
Oct 20, 2009 12:23 PM
chiLLaxcd7
Dec 17, 2008 09:51 PM
