did anyone buy the s/t adapter kit?
Old May 12, 2007 | 01:54 PM
SFlCrx's Avatar
Default did anyone buy the s/t adapter kit?
i was about to buy the suspension technique rear sway bar on summit and looked at the suggested parts and there is an adapter kit for like $52. i was told everything that was needed came with the sway bar.so why is there an adapter kit?
Modified by SFlCrx at 11:28 AM 5/13/2007
Old May 13, 2007 | 07:26 AM
SFlCrx's Avatar
bump
Old May 13, 2007 | 07:30 AM
esteen2's Avatar
Default Re: (SFlCrx)
The adapter kit is for 88 civic with itr style lower control arm. I bought one, but if I had seen one first I would not have paid so much for something you could make for $2.00
Old May 13, 2007 | 08:12 AM
Bob_760's Avatar
Default Re: (S2R Honda)
Is the kit needed if you have an 88 with 89-91 LCAs?
Also what exactly is the kit?
Old May 13, 2007 | 09:52 AM
SFlCrx's Avatar
Default Re: (Bob_760)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob_760 &raquo;</TD></TR><TR><TD CLASS="quote">Is the kit needed if you have an 88 with 89-91 LCAs?
Also what exactly is the kit?</TD></TR></TABLE>
no. its just an adapter kit i am assuming.
so what do i need to put it on, i have a 88 hf.
Old May 13, 2007 | 12:32 PM
esteen2's Avatar
i will try to get a pic up of mine. It look's like a small piece of angle iron with two holes drilled in it.
Old May 13, 2007 | 03:11 PM
Crx Jimmy's Avatar
I thought they included that piece for cars without the swaybar hole in the arm? you might want to just ask summit or S/T
Old May 13, 2007 | 05:00 PM
SFlCrx's Avatar
Default Re: (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">I thought they included that piece for cars without the swaybar hole in the arm? you might want to just ask summit or S/T</TD></TR></TABLE>
yea me, too the hole is there is just not threaded i think
Old May 15, 2007 | 07:21 PM
SFlCrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2R Honda &raquo;</TD></TR><TR><TD CLASS="quote">i will try to get a pic up of mine. It look's like a small piece of angle iron with two holes drilled in it.</TD></TR></TABLE>
get the pic for me?
Old May 22, 2007 | 08:21 AM
SFlCrx's Avatar
anyone have a pic of what i can use to put the sway bar in? without the adapter or should i just get the adapter kit?
6jcomshop
Sep 1, 2018 02:07 PM
jonnybravo
Nov 21, 2003 11:11 AM
. o 69 o .
Jan 8, 2003 05:43 PM
grngsr01
Oct 3, 2002 11:22 AM
