eg6 project
Hi guys i live in Brazil and bought most of the parts of my project in importparts, i would like to share some pix of it with you.
This one was taken on nelson piquets race course in Rio de Janeiro.
Sry, since i am new i can't edit the topic since the pics where in diferent sizes i recised them ad some new one´s an put it in order.
i am using a b16a2 cause its the engine that came with this car in brazil between 1993 and 1998 in the VTI model.
as i said before most parts of the project i bought from importparts, and Ben has been like a guru being very pacient and helping a lot with the project.
i hope i can share my experienes and get some good tips here for the project.
i haven't noticed that there were no picture with the tail lights on it, here it goes.
i took a brake this weekend but next one there will be photos with engine on it probably, i am building an interesting fuel line too and will be using a big oil cooler, pix soon.
This wilwood kit requires 17" wheels, but in the endo of the project it wont be a problem, ill probably need more than 215 toyo r888 to get some grip with 600 whp.
as soon as possible ill import an engine block with darton sleeves.
the actual set up can hold 300 whp.
i popped out the grills cause of the intercooler, and i was thinking of makin an air ram for the brakes cause this car will be used in trackdays so the brakes suffers a lot.
ill probably put some kind of thin grill just to protect the cooler from rocks and things like that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cookie »</TD></TR><TR><TD CLASS="quote">What size wheel does this kit require? 17's? Nice build up, btw!
Please make sure you use undercoating in the wheel wheels so it doesnt look all overprayed like it is
Lose the tails
</TD></TR></TABLE>Please make sure you use undercoating in the wheel wheels so it doesnt look all overprayed like it is
Lose the tails
some more pictures of the project.
tsuya wheels with pirelli p zero nero tires 205/40/17"
tein ss coil overs and powerslot rear discs
ingals camber kit
energy suspension bushings
willwood dynalite brake kit
skunk 2 camber kit
tein ss
mattrix rear upper bar
greddy filter relocator
fluidyne radiator
samco hoses
fal fan
lyco racing seats and sparco belts
removing the ventilation system and everything else that i can from under the dash
removing gauge for changing for ac s7 gauges
now i am waiting for some tips to change the gauges
ingals camber kit
skunk 2 camber kit
tein ss
fluidyne radiator
samco hoses
fal fan
I hope you dont dump your used oil on the ground all the time like that!
On to the conclusion of the on the losing of the tails thats why its his car and not yours.
What are your goals for horsepower?
, como vai voce haha thats all i knoe in portugues
