Does anybody think this is a good deal?
Old May 31, 2002 | 12:51 PM
TheHater
Guest
Posts: n/a
Default Does anybody think this is a good deal?
$5167.00
DRAG Gen III Turbo System
DRAG Cast Iron Manifold
Turbonetic Garret T3/T04 B or Etrim Hybrid Turbo
Spearco Core w/ DRAG Cast Iron End Tanks Intercooler
Deltagate (5-7psi Spring)
HKS Super Sequential BOV 2.25"
Aluminzed Mandrel Bent Piping 2.5" Downpipe
Vortec Fuel Pressure Regulator
DRAG Intake and Filter
Chrome Intercooler and turbo pipings
DRAG Dump Tube
DRAG Check Valve
Purosil Hoses & Clamps
High Volume Fuel Pump
Oil Feed Line Oil Return Line
High Pressure Silicon Hose
Neccessary Vacuum Tee's Neccessary Vacuum Lines
GReddy Boost Gauge
GReddy Rebic IV Fuel Injector Controller
GReddy Turbo Timer
HKS 480 cc/min Injector x 2
HKS Fuel Cut Defenser
HKS Injector Connector
HKS Injector O-ring
HKS Steel Injector Cinch Fitting
HKS Variable Boost Controller
MSD 6A Boost Timing Master Ignition Control
TIAL 35mm W/G (OPTIONAL)
Old May 31, 2002 | 12:54 PM
b18bturbo's Avatar
Default Re: Does anybody think this is a good deal? (BOOSTINSI)
thats alot of uncessary stuff. You dont need half that stuff.
I would ditch the rebic IV and all the HKS fuel accesories. I would get a hondata stg 3b or 4b depending on what you want.
Drag KIT 2600 + 1300 for hondata+270 for injectors 4170
[Modified by b18bturbo, 3:58 PM 5/31/2002]
Old May 31, 2002 | 12:55 PM
vtecvoodoo's Avatar
Future Texas Boy
I don`t.
Old May 31, 2002 | 12:58 PM
TheHater
Guest
Posts: n/a
Default Re: Does anybody think this is a good deal? (b18bturbo)
Hey thats true but will hondata do the job that the rebic 4 does. Does hondata control nitrous.(sorry im a newbie.)
Old May 31, 2002 | 01:04 PM
SIK IN DA HED's Avatar
New User
thats exactly what i was thinking.
Old May 31, 2002 | 01:05 PM
b18bturbo's Avatar
rebic doesnt control nitrous or anything like that either.
The hondata does though control fuel and timing its complete stdalone that does pretty much what you need it to do. If you wnat to do nitrous as well get an AEM ems it has the output to control the nitrous.
tonydatyga's Avatar
$5167.00... budget racer says that enough for an entire setup including shell/engine.
Old May 31, 2002 | 01:11 PM
TheHater
Guest
Posts: n/a
Thanks B18 Turbo you always seem to have the right answers.
Touch
May 28, 2003 11:27 AM
Touch
May 24, 2003 07:24 PM
TheHater
May 29, 2002 01:08 PM
integra-modder
May 22, 2002 07:23 PM
CleanCL
May 10, 2002 02:09 PM
