Help! rear disc conversion?
Old May 12, 2007 | 11:33 AM
b16aeghatch's Avatar
Default Help! rear disc conversion?
i have an 95 dx hatch and am looking to do a rear disc conversion. i have the trailing arms with rotors and calipers from a 90 model da teg. What will i need to make these work or will they even work? couldnt i just change out the spindle and all the components?
Old May 12, 2007 | 11:47 AM
EGLUVN's Avatar
Default Re: Help! rear disc conversion? (b16aeghatch)
I don't exactly know about the spindle. I just had mine done by a friend. But I do know that it is good to replace the porportioning valve. One from a Teg or something. Check your wheel bearing before installation. It makes it a lot easier to replace if necessary.
Old May 12, 2007 | 12:57 PM
Mr.EM1_EK's Avatar
Default Re: Help! rear disc conversion? (EGLUVN)
here this should help.
https://honda-tech.com/zerothread?id=1513752
https://honda-tech.com/zerothread?id=812062
if that does not help learn to use that nifty search button.
bluenc-87
Apr 18, 2010 09:44 PM
J.P.
Feb 14, 2003 10:25 PM
b18crx
Nov 25, 2002 07:13 AM
Guam_CiviC619
Aug 14, 2002 11:51 PM
