Honda S2000 Honda S2000
So what REALLY happens when you miss a gear in your S2K?
Old May 12, 2007 | 10:44 AM
Ross 2.0's Avatar
In a Junkyard near you.
Default So what REALLY happens when you miss a gear in your S2K?
http://www.flickr.com/photos/moogocow3/495110533/
http://www.flickr.com/photos/moogocow3/495075164/
http://www.flickr.com/photos/moogocow3/495112025/
http://www.flickr.com/photos/moogocow3/495078314/
Old May 12, 2007 | 11:01 AM
Honda-Hooligan's Avatar
Default Re: So what REALLY happens when you miss a gear in your S2K? (Evil Monkey)
miss gear or shifted into wrong gear?
Old May 12, 2007 | 11:03 AM
Ross 2.0's Avatar
They won't confess.
According to the customer they were driving down the road and a puff of blue smoke came out. Then the engine died.
Funny thing is the car ran for like 5 seconds when we went to pull it in.
Old May 12, 2007 | 12:11 PM
cmdr430's Avatar
Default Re: (Evil Monkey)
looking at the rear bumper, it has definately been driven hard and put up wet....
my s2k rear bumper has never looked like that no matter how hard i drive it.....
and i run mobil 1....
now on my old 98 itr, that was a different story, the bumper always looked like that no matter how it was driven......an no matter what oil i used.....
if it was a 00-01 that may be from the spark plug tsb.....but seeing that the rear window is glass it is an 02+
Old May 12, 2007 | 01:21 PM
Default Re: So what REALLY happens when you miss a gear in your S2K? (Honda-Hooligan)
this looks like wut happend to my buddy on his 99 m3 ofcurse it was worse on his. wut he did was shift into 2nd gear when he was supossed to shift to 4th
Old May 12, 2007 | 04:06 PM
whitey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda-Hooligan &raquo;</TD></TR><TR><TD CLASS="quote">this looks like wut happend to my buddy on his 99 m3 ofcurse it was worse on his. wut he did was shift into 2nd gear when he was supossed to shift to 4th</TD></TR></TABLE>
I did the same thing, from 3rd to 2nd in my S2k. Bent all valves, broke two valve guides, cracked all the retainers, and lightly tapped one of the pistons but nothing happend to the piston.
I did all the work myself and saved hella money....
I learned my lesson....
Old May 12, 2007 | 09:19 PM
ednyboo's Avatar
that looks like a street racer s2k
Old May 12, 2007 | 11:29 PM
Curiouz_G's Avatar
it looks like he mustve been flooring it and shifting into 2nd gear on accident while STILL flooring it or at a high RPM
Old May 14, 2007 | 04:51 PM
Shy_GuyAP1's Avatar
The rear bumper could just be from the exhaust not pertruding from the bumper enough, when they are sitting the exhaust heat will go up and burn the bumper. I see it everyday on cars with cheap exhausts.
What is this sparkplug TSB on the 2001 model?
Old May 14, 2007 | 05:04 PM
Ross 2.0's Avatar
Default Re: (Shy_GuyAP1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shy_GuyAP1 &raquo;</TD></TR><TR><TD CLASS="quote">The rear bumper could just be from the exhaust not pertruding from the bumper enough, when they are sitting the exhaust heat will go up and burn the bumper. I see it everyday on cars with cheap exhausts.
What is this sparkplug TSB on the 2001 model?</TD></TR></TABLE>
not by far....
Old May 14, 2007 | 05:15 PM
Shadowz7429's Avatar
ouch
RACEPAK
Aug 30, 2007 06:31 PM
Fo-Do Fanatic
Jan 12, 2007 10:40 AM
Yosshaa
Honda S2000
Aug 26, 2005 04:17 PM
