anyone rocking ground controls on their 4th gens?
Old May 12, 2007 | 08:23 AM
rch022's Avatar
Default anyone rocking ground controls on their 4th gens?
Is anyone using these on their 4th gens? I plan on buying some and want to know how they ride and if you can tuck tire no problem(ppl are having trouble w/other coilover suspensions). Also right now i'm riding on tein s-tech's w/tokiko illuminas, would I just be able to swap out the tein's for the GC's, and how hard would this be? thanks in advance
Old May 12, 2007 | 01:20 PM
jdmlude5
Guest
Posts: n/a
Default Re: anyone rocking ground controls on their 4th gens? (rch022)
i am useing them. they ride good to me. no complants
Old May 12, 2007 | 01:22 PM
BlownH23a
Guest
Posts: n/a
swaping springs is easy, takes about 30 mins per wheel..u need a set of spring compressors, just get them from autozone.
Old May 12, 2007 | 01:28 PM
rch022's Avatar
Default Re: anyone rocking ground controls on their 4th gens? (jdmlude5)
how much would a set of spring compressors cost me(i'm a cheapass lol)
Old May 12, 2007 | 01:31 PM
rch022's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlude5 &raquo;</TD></TR><TR><TD CLASS="quote">i am useing them. they ride good to me. no complants
can you tuck tire w/them? and you got any pics of ur setup
Old May 12, 2007 | 02:56 PM
BlownH23a
Guest
Posts: n/a
you can rent them i think, if not they are like 30 or 40 dollars..and why would u want to tuck your tires? your losing steering angle and suspension travel...
Old May 12, 2007 | 10:26 PM
samurhai's Avatar
Default Re: (BlownH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlownH23a &raquo;</TD></TR><TR><TD CLASS="quote">swaping springs is easy, takes about 30 mins per wheel..u need a set of spring compressors, just get them from autozone.</TD></TR></TABLE>
you sure? i put on tokico blues and tein s-techs without needing a spring compressor..
Old May 12, 2007 | 10:55 PM
LudeBehavi0r's Avatar
I honestly cant see why tire tucking is of upmost concern to u. Do u realize u have 2034587420852 thing that are more important than being able to tuck ur tires on a "sports car"?
Being able to tuck ur tires possesses the least amt of importance on ur car unless ur 100% about just tryin to "impress" ppl. If u wanted to impress us here in the "Prelude" forum u'd ask something along the lines of a topic that had to do with camber/toe or something else more technical than sayin u wanna tuck ur tires and ur cheap......
Old May 13, 2007 | 07:06 AM
93sivtec's Avatar
If u are swapping out springs and struts,then u will not need a spring compressor.If u use the struts u currently have and put new springs on them,then yes u will need a spring compressor.
Old May 13, 2007 | 07:17 AM
jdmlude5
Guest
Posts: n/a
well mine are 3/4 of the way down. tucking about 1/4 inch tire. on 16 inch rims w/205 50 16
Old May 13, 2007 | 08:55 AM
rch022's Avatar
Default Re: (LudeBehavi0r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeBehavi0r &raquo;</TD></TR><TR><TD CLASS="quote">I honestly cant see why tire tucking is of upmost concern to u. Do u realize u have 2034587420852 thing that are more important than being able to tuck ur tires on a "sports car"?
Being able to tuck ur tires possesses the least amt of importance on ur car unless ur 100% about just tryin to "impress" ppl. If u wanted to impress us here in the "Prelude" forum u'd ask something along the lines of a topic that had to do with camber/toe or something else more technical than sayin u wanna tuck ur tires and ur cheap......</TD></TR></TABLE>
no sorry i'm not trying to impress you, and i'm not looking to build a racecar, just a DD taht looks good, and handles better than stock, thanks
Old May 13, 2007 | 11:22 AM
Default Re: (rch022)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rch022 &raquo;</TD></TR><TR><TD CLASS="quote">
no sorry i'm not trying to impress you, and i'm not looking to build a racecar, just a DD taht looks good, and handles better than stock, thanks</TD></TR></TABLE>
Tucking tires does not equal good handling
Old May 13, 2007 | 12:37 PM
BlownH23a
Guest
Posts: n/a
hes must be referring to the" jdm tight yo guide to going fast".
Old May 13, 2007 | 12:39 PM
JDMgareth's Avatar
RACECAR! ZROOM ZROOM
evil sol
Suspension & Brakes
22
Jun 3, 2010 10:57 AM
eluam
Jan 5, 2008 06:34 PM
sugz
Suspension & Brakes
Nov 6, 2006 08:34 PM
evolvedAP1
Jul 8, 2006 06:29 PM
91tealhatch
Suspension & Brakes
Mar 21, 2006 01:53 PM
