k24 crvtec
Old May 12, 2007 | 12:39 AM
primetime's Avatar
Default k24 crvtec
ok I have been doing search's for the last three days. I know you have to mod the oil pump from the type s to get it to fit on the k24 does anybody know what exactly has to be modded? thanks in advance
Old May 12, 2007 | 08:00 PM
risktypeS's Avatar
Default Re: k24 crvtec (primetime)
http://www.sportcompactcarweb.....html <==== read the whole thing.
Old May 13, 2007 | 08:43 AM
primetime's Avatar
Default Re: k24 crvtec (risktypeS)
thanks for the link
Old May 13, 2007 | 09:02 AM
risktypeS's Avatar
yep... you'll find all your answers in there.
Old May 14, 2007 | 08:33 AM
smooth95's Avatar
http://forums.clubrsx.com/showthread.php?t=392509
Old May 14, 2007 | 09:13 AM
risktypeS's Avatar
Default Re: (smooth95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smooth95 &raquo;</TD></TR><TR><TD CLASS="quote">http://forums.clubrsx.com/showthread.php?t=392509</TD></TR></TABLE>
was just going thru it briefly and this one is better then the one i gave you. Use both for guidance.
nice post smooth95
Old May 20, 2007 | 10:52 PM
primetime's Avatar
Default Re: (risktypeS)
ok I was reading a post some where that said if you do an engine swap and in the rsx you would throw the immobilizer light if you did not turn that off in kpro. I was under the impression that the immobilizer was slaved to the ecu not the engine, can anyone clarify this, thanks
Old May 21, 2007 | 06:03 AM
risktypeS's Avatar
Default Re: (primetime)
the immobilizer is programmed to the key that came with the car and the ecu. So if you were to get hondata and told them to just send you an ecu that is already ready, then you'd have to get that ecu reprogrammed to your immobilzer and key unless you told them you wanted to keep the ecu you sent in. that help?
gentek1145
Honda Civic (2006 - 2015)
Jan 14, 2007 01:45 PM
honda_mike
Dec 20, 2006 10:31 AM
awdriscol4
Apr 13, 2005 08:17 PM
JMD
Mar 21, 2004 07:16 PM
Stryker908
Mar 27, 2003 01:49 PM
