?!?!?!?!?!URGENT, LS swap problems wit TB cable?!?!?!?!
Old May 11, 2007 | 02:58 PM
Xscort's Avatar
Default ?!?!?!?!?!URGENT, LS swap problems wit TB cable?!?!?!?!
Left:d15, Right '97 GSR
I have both the d15 TB cable and a 97 GSR cable! Neither one mounts on to the IM. I dont have time to custom make a bracket. I thought the LS swap was straight forward!!
d15 mounted and cable will not reach, and the GSR is even worse!
Old May 11, 2007 | 03:04 PM
93ls10.0's Avatar
Default Re: ?!?!?!?!?!URGENT, LS swap problems wit TB cable?!?!?!?! (Xscort)
the ls swap it straight forward you need an ls throttle cable the one for the year you motor is that way it bolts to the stock bracket on the manifold it's as easy as that.
Old May 11, 2007 | 03:05 PM
dannis.'s Avatar
Are you positive that its a gsr cable? cause it shouldn't be shorter then a d15...
Old May 11, 2007 | 03:11 PM
Xscort's Avatar
Default Re: ?!?!?!?!?!URGENT, LS swap problems wit TB cable?!?!?!?! (dannis.)
i could be wrong...but i went str8 to the junkyard and pulled it myself from a 97 GSR. had to pay $21 freakin dollars.
Old May 11, 2007 | 03:12 PM
Xscort's Avatar
so i guess i gotta go look for a b18b throttle cable huh?? damn its gonna be hard to find one here in columbia.
Old May 11, 2007 | 03:30 PM
Jtuned DC2's Avatar
* B A N N E D *
What kind of manifold is it? Just a regular LS manifold? Then get the b18b throttle cable. If its a skunk2, you gotta get a type-r Bracket
Old May 11, 2007 | 03:32 PM
Xscort's Avatar
Default Re: (KevLo)
its the 98 LS b18b IM. I'll just try to look for an LS b18b throttle cable. Is there a difference between the manual vs. automatic throttle cables in the 94-2001 b18b tegs??
Old May 11, 2007 | 03:37 PM
Luserkid's Avatar
Default Re: (Xscort)
Yea i had the same problem before. Ended up making a simple bracket out of aluminum. But yea LS throttle cable is way different.
Old May 11, 2007 | 04:54 PM
Xscort's Avatar
Default Re: (Luserkid)
thanks for the help guys!!! i'll let u kno how everything turns out!
Old May 12, 2007 | 07:09 PM
viahiptop's Avatar
yes you will need a LS TB cable and bracket for your LS setup
standbackimapro
Feb 12, 2009 06:20 PM
g0tgot
Oct 11, 2008 07:50 AM
mike1jag
May 19, 2007 09:08 PM
admess188
Apr 12, 2007 03:47 AM
GSRacer
Oct 9, 2001 04:53 AM
