Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
torque wrench specs for suspension, exhaust mods
Old May 11, 2007 | 02:21 PM
Default torque wrench specs for suspension, exhaust mods
Im curious as to where i can find torque wrench specs for when i put on my lowering springs, skunk2 camber kit and exhaust. how tight are the bolts torqued. thanks in advance if anyone knows.
Old May 11, 2007 | 02:26 PM
Rahxephon's Avatar
Default Re: torque wrench specs for suspension, exhaust mods ("Ridge"Racer)
collegehillhonda.com go to their hpf suspension there should be an instruction.
Old May 11, 2007 | 02:34 PM
exhaust_note's Avatar
Default Re: torque wrench specs for suspension, exhaust mods (Rahxephon)
last time i ever used a torque wrench was for head work, cams etc.
you dont need that.
Old May 11, 2007 | 02:45 PM
Default Re: torque wrench specs for suspension, exhaust mods (exhaust_note)
yeah, this will be my first DIY install of any sort, ive done my homework and thats the last thing bugging me, i just want to do it right and not mess anything up. thanks Rahxephon for the reference, got the info, but like you said and even imo i dont see why torque specs would be pertinent.
Old May 11, 2007 | 02:53 PM
06civicracer's Avatar
what exhaust_note said,you only need the right torque specs for engine mods
Old May 11, 2007 | 03:02 PM
Default Re: torque wrench specs for suspension, exhaust mods (06civicracer)
well im going off of the hfp muffler for the si, it does give specs, but not for the entire exhaust, only muffler. does it matter if i just tighten it tight as hell??
Old May 11, 2007 | 03:34 PM
nah.. dont go tight as hell. your stronger then you thing.. wrist tight is something like 25-35 ft. lbs.
a nice body shrug is like 60-70.. so give it a few nice body shrugs. i got that feel now.. most people who have messed around alot and have snapped bolts can start to feel them twist and know when to stop.
Old May 11, 2007 | 03:54 PM
also sais im supposed tighten everything with the weight of the car on the suspension. how the hell do i get around the wheel to tighten bolts when the wheel is on??????????????
Old May 11, 2007 | 04:33 PM
Ouija's Avatar
Park over a hole
The honest answer here is carefully. You'll be able to figure it out when you're actually looking at it. Sometimes it's best to just do rather than worry about doing.
Old May 11, 2007 | 05:57 PM
Nighthawk R18's Avatar
Default Re: torque wrench specs for suspension, exhaust mods (Ouija)
i torque my wheels to 80. someone somewhere told me 80 so 80 it is.
Old May 11, 2007 | 06:52 PM
20strong's Avatar
To Nighthawk your wheel torque spec should be 90 FT LBS. To the OP use the German method of goodntight.
Old May 13, 2007 | 04:35 AM
marshall81's Avatar
True backyard mechanics...It's better to get the torque specs then to under tighten it and have something fall off over time or to over tighten it have have the bolt break
Old May 13, 2007 | 06:31 AM
Default Re: torque wrench specs for suspension, exhaust mods (marshall81)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marshall81 &raquo;</TD></TR><TR><TD CLASS="quote">
True backyard mechanics...It's better to get the torque specs then to under tighten it and have something fall off over time or to over tighten it have have the bolt break</TD></TR></TABLE>
i don't no any dealerships that use the torque specs for things like brakes, suspension and such.
tpot90
Mar 15, 2009 06:31 AM
jacob1217
Aug 23, 2007 05:05 PM
crxss outhe eyes
Jan 24, 2007 04:31 PM
Ding
Aug 25, 2005 11:13 AM
