RAGE HEADER QUESTION IN A 90 HB
Old May 11, 2007 | 07:26 AM
b16civster's Avatar
Default RAGE HEADER QUESTION IN A 90 HB
well like it says i just want to know if it will fit with a full size radiator??? i know i need a traction bar to clear the cross member soooooo....
Old May 11, 2007 | 03:45 PM
b16civster's Avatar
Default Re: RAGE HEADER QUESTION IN A 90 HB (b16civster)
bumpage
Old May 12, 2007 | 06:56 AM
b16civster's Avatar
bumpage for some knowledge
Old May 12, 2007 | 10:42 AM
steronz's Avatar
mine fits fine with a koyo double-thick full size. radiator clearance isn't a problem. but i did have to sell my jimfab crossmember and get an ESP one that hangs lower and further forward.
Old May 12, 2007 | 11:59 AM
b16civster's Avatar
Default Re: (steronz)
where do you get the esp traction bar??? and how do you like it?
Old May 12, 2007 | 12:07 PM
b16civster's Avatar
Default Re: (b16civster)
ALSO DO YOU HAVE ANY PICS OF YOUR SETUP?? I WOULD LOVE TO SEE IT
Old May 12, 2007 | 12:22 PM
Suck my DX's Avatar
no problem clearing the radiator...
i actually was able to make mine work with the stock crossmember, but it took quite a bit of work...
however i warn you, the way these engines sit in the EF chassis, if your car is lowered, you will have no practical ground clearance...i put a dent in mine while i was driving and i went over a small bump in the road and bottomed out the header on the concrete...in my eg ive ran into no ground clearance problems yet
Old May 12, 2007 | 12:27 PM
b16civster's Avatar
Default Re: (Suck my DX)
DO YOU HAVE A PIC OF THE CLEARANCE ON THE HEADER AND ON THE CROSSMEMBER
Old May 12, 2007 | 12:30 PM
Suck my DX's Avatar
maybe...let me check my photobucket
Old May 12, 2007 | 12:34 PM
Suck my DX's Avatar
as you can see the radiator clearance is more than enough, but look how much i needed to remove from the crossmember....
i wouldnt advise doing what i did unless you weld in indented plates where you cut or else that thing is gonna bend or break....you need a traction bar to clear this header for sure....i dont have a pic saved of the ground clearance but i remember posting it in a thread once, let me see if i can find it
Old May 12, 2007 | 12:52 PM
tougetuned_ef's Avatar
if your car is slammed then your going to have like 2in. max clearance. my ef is lowered 2.25 front, about 1in wheel gap on 14s and i have 5.5in. of clearance with stock b16 header. i know ill have plenty when i get a crossmember and a 4to1 header.
Old May 12, 2007 | 01:04 PM
Suck my DX's Avatar
Default Re: RAGE HEADER QUESTION IN A 90 HB (tougetuned_ef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tougetuned_ef &raquo;</TD></TR><TR><TD CLASS="quote">if your car is slammed then your going to have like 2in. max clearance. my ef is lowered 2.25 front, about 1in wheel gap on 14s and i have 5.5in. of clearance with stock b16 header. i know ill have plenty when i get a crossmember and a 4to1 header. </TD></TR></TABLE>
yeah you keep thinking that and well see what happens when you get a 4-1...
you cant compare the dimensions of the b16 manifold to the rage...they are nothing alike..
BTW the rage isnt even a 4-1 header...
Old May 12, 2007 | 01:18 PM
menappi's Avatar
That's a beefy *** header, never seen that. Is it safe having the crossmember sliced up like that?
Old May 12, 2007 | 02:25 PM
steronz's Avatar
i got the traction bar from here:
http://www.explicitspeedperformance.net/
i'm not all that crazy about the design, but it's plenty beefy, leaves plenty of room, and is much better than stock.
i don't have too many good pictures of the setup, but here's proof that the header fits with the koyo monster:
Old May 12, 2007 | 08:12 PM
b16civster's Avatar
NICE PICS got any under car shots??
Old May 12, 2007 | 08:47 PM
steronz's Avatar
not at the moment.
Old May 12, 2007 | 09:06 PM
Jokester's Avatar
Most people just remove the cross member in favor of the traction control bar setup.
Old May 13, 2007 | 04:48 AM
eviled's Avatar
Default Re: RAGE HEADER QUESTION IN A 90 HB (Jokester)
which koyo rad is that? are the hose inlet and outlets correctly sized??
Ed
Old May 13, 2007 | 07:19 AM
b16civster's Avatar
Default Re: RAGE HEADER QUESTION IN A 90 HB (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">
BTW the rage isnt even a 4-1 header...</TD></TR></TABLE>
how much clearance do you think ill have????/ im going to be lowered (not slamed) but i should have more clearence then a 4into1......right????
Old May 13, 2007 | 01:09 PM
b16civster's Avatar
bump for some ground clearence info
Old May 13, 2007 | 02:52 PM
Suck my DX's Avatar
Default Re: (menappi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menappi &raquo;</TD></TR><TR><TD CLASS="quote">That's a beefy *** header, never seen that. Is it safe having the crossmember sliced up like that?</TD></TR></TABLE>
not really....you cant see it in the pic but i welded a contoured plate where i cut to add strength....i just did that temporarily so that i could run the header till i got my traction bar, but i ended up getting rid of the car before i got it,so it stayed that way...if you just leave it cut like that, its very dangerous..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16civster &raquo;</TD></TR><TR><TD CLASS="quote">
how much clearance do you think ill have????/ im going to be lowered (not slamed) but i should have more clearence then a 4into1......right????</TD></TR></TABLE>
what mounts are you using? what is your suspension setup? what motor is this going on?
Old May 13, 2007 | 04:33 PM
ozrednsx's Avatar
Default Re: RAGE HEADER QUESTION IN A 90 HB (eviled)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eviled &raquo;</TD></TR><TR><TD CLASS="quote">which koyo rad is that? are the hose inlet and outlets correctly sized??
Ed</TD></TR></TABLE>
would like to know as well
Old May 14, 2007 | 07:36 AM
b16civster's Avatar
what mounts are you using? what is your suspension setup? what motor is this going on?</TD></TR></TABLE>
avid racing mounts on a ls/v
Old May 14, 2007 | 08:51 AM
Suck my DX's Avatar
what suspension are you running...ride height is going to be the determining factor here.
Old May 14, 2007 | 04:52 PM
b16civster's Avatar
tein ef6 coilovers
