EVAP Purge Congrol Solenoid Valve clicking?
Old May 11, 2007 | 07:17 AM
chibiko's Avatar
Default EVAP Purge Congrol Solenoid Valve clicking?
Found that my 97 accord EVAP valve clicking (louder than the cylinder valves) after the car is turned on. I found this using a stethoscope. Is its clicking normal? or I need to replace it?
Thanks.
Old May 11, 2007 | 09:20 AM
JimBlake's Avatar
Default Re: EVAP Purge Congrol Solenoid Valve clicking? (chibiko)
It's supposed to open & close while the engine runs. Since you needed a stethoscope to hear it, maybe it's not much louder than normal?
Old May 11, 2007 | 10:08 PM
chibiko's Avatar
Default Re: EVAP Purge Congrol Solenoid Valve clicking? (JimBlake)
I can hear it by ear. But since there are multiple components in that area, I need to use a stethoscope to locate which one is clicking.
Old May 12, 2007 | 04:23 AM
JimBlake's Avatar
If it wasn't working, your CEL should come one. Maybe it'll go for a long time like that before it quits working. Check out what it costs. If it's cheap, get one. Or since it's relatively easy to get at, just keep an eye on it.
Old May 12, 2007 | 04:36 AM
Ross 2.0's Avatar
In a Junkyard near you.
that's 100% normal. The PCS works on duty cycles so the rapid clicking your hearing is just the duty cycle. Say the computer tells it to run on 80%, it's going to be open 80% of the time. Hence the rapid clicking you are hearing from it
midnitesol
Mar 12, 2011 07:23 PM
ArmaanOG
Apr 8, 2009 03:16 AM
Dav94Lx
Oct 9, 2007 07:53 PM
XenonDepot
Apr 18, 2003 12:44 AM
