timing belt replaced, now misfiring
I just changed the timing belt, head gasket and balancer shaft belt on a 97 accord and now it runs really rought like it is misfiring. While it is running, if i pull off #1 or #2 spark plug wire or injector plug, there is no change in idle. If i do the same thing to number 3 or 4, the car dies or there is a huge change in idle. The timing is dead on, I am not sure what to do
better check your timing marks agian sounds like your off a tooth real easy to do there a couple of ways all depends on witch motor you have find some body that has a picture of how the timing marks line up good luck
pimpwagon
Nov 12, 2010 08:41 AM
Y2KCivicSiR
May 9, 2005 09:56 PM
