ecu pins
i posted about removing the pins out of my ecu, and asked what tool i should use. i got a couple responses saying that a mini screwdriver would work. is this true or should i use something else?and if its alright to use then how would i go about removing the pins with it? i heard hasport has a tool but i couldnt find it. thanks for the help.
I've always used a small screw driver. It's hard to explain, but just stare at the plug a while. There is a little plastic catch that you need to depress in order for the pin to slide out.
i went to the junk yard and cut off the ecu plugs and 6 inches of wire and praticed on that, i used an sewing needle at first but that was a bitch then i tired an eye glass screw driver and that worked wonders
