how to clean wheels ...?
i just got my desmond reggamasters from icb and there used but in good condition i juss wana clean them does anyone know wat i can use i started to use soap and water and sos but does anyone else have any other trick i can use thanx........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazi_E »</TD></TR><TR><TD CLASS="quote">peanut butter</TD></TR></TABLE> yuppp...i have seen good results w/that
i just use good ole soap and water...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drvtecteg »</TD></TR><TR><TD CLASS="quote">i just got my desmond reggamasters from icb and there used but in good condition i juss wana clean them does anyone know wat i can use i started to use soap and water and sos but does anyone else have any other trick i can use thanx........ </TD></TR></TABLE>
Aren't S.O.S. pads ABRASIVE?!
Why would you wanna scratch up your wheels??
I usually just spray them down with wheel cleaner and let them sit for a minute, then spray again and buff with a wet/damp cloth. Rinse thoroughly and repeat.
clean wheels with soap and water.
then spray the wheel down with the teflon cleaner ..let soak for 30sec. then scrub the wheel clean ...spray down with water again..and dry.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc5 jared »</TD></TR><TR><TD CLASS="quote">
bump if anybody tried this and can show pictures!
</TD></TR></TABLE>bump if anybody tried this and can show pictures!
use dish soap and baking soda. i clean my hands with it and its super strong. just sprinkle some bs on it, and then make a soapy solution in a spritzer bottle and wet the wheels up and clean with a tooth brush.
i live by this method...best wheel cleaner in the market...know your teflon and you will never look back!!!
</TD></TR></TABLE>i live by this method...best wheel cleaner in the market...know your teflon and you will never look back!!!
yeah but if you're cleaning wheels for painting them, peanut butter is awful because it leaves being an oily residue which will cause fisheyes. Thats why I suggested dishsoap, and if it needs extra cleaning dishsoap+baking soda. It cuts the grease
wash em, wax them w/mother's deep cleaning, its regularly for cleaning paint on the car but if they are silver or white powder coated regas this could be your answer....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers »</TD></TR><TR><TD CLASS="quote">list of quotes</TD></TR></TABLE>
Was that necessary?
If anyone has ever used a citrus based wheel cleanser, be careful, because that can actually degrade the clear coat on wheels. Teflon-based is a much better wheel cleanser.
Was that necessary?
da1nfamous
15
Nov 30, 2003 08:20 PM
