Stewarts CRX build (pics) 56k Mabye
Well, this is how it goes, I bought a CRX from a guy and he told me it was a B18 and then it came with a Rolling Chassis. Now this is early in my Engine days were I didnt know all that much. A year later it still sits in my yard waiting for that Engine to be put in. I gained the motivation and in about 4 hours I put the tranny on and put the engine int he car all wired and ready to go. The next day I went out and fired it up for about 10 seconds just to see if it was runnable. It was even with all the crud ont he plugs and whatnot. Well it turns out after some extensive research its a B16A. Took me a bit to figure out the wiring but I got it all done and she ran and I was olmost shocked with about 6 hours of work I put the engine in without a cherry picker. Its dirty I know but hey, its my first honda project. I am 17 btw and all I have under my belt is a Turbo Cavalier all done by me, a Turbo RX-7 all by me and now this. I plan to turbo this or get a B18 lower end and stick it in there so I can get some real numbers outa it.
I need some help though, I dont have any axels its just a tranny in there. Do I need
Axel/Halfshaft/Axel or do hondas just have 2 axels? or what. I know I need them from a 90-93 teg right? How much do you think it would be?
One more thing, I have a PYR PR4 "Racing" ECU It says B18A on it. Is this a LS ECU or a Vtec cuz I think it might be LS :-/
On with the pictures. Thanks guys the build will be kept updated.
that thing runs???..... j/k
pr4 is an ls ecu and i believe b-series are axle/halfshaft/axle.... they shouldnt be too expensive
good luck gettin that thing pimpin
I was just reading something and someone asked if they needed the oil pressure sensor for there Vtec to work then they said that there ECU doesnt control Vtec so question, with a PR4 could I potentially still have a working Vtec system?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3xcrx »</TD></TR><TR><TD CLASS="quote">I was just reading something and someone asked if they needed the oil pressure sensor for there Vtec to work then they said that there ECU doesnt control Vtec so question, with a PR4 could I potentially still have a working Vtec system?</TD></TR></TABLE>
Yes you could still make it "work" but not the most efficient way.....
Get the correct computer.
As for the axles, you need a halfshaft and axle on the drivers side and just and axel on the passenger side. And yes 90-93, you need to remove the retaining rings on the backside of the hubs, you'll see a little lip back there with the axle out and you just pop it out, and slide in the DA axles.
Question, does anyone know were i could get directions of how to assemble the shift linkage i shearch but failed. All i have is the shifter and the rod going back to the hole. No mounting hardware or anything someone said I need a peiced to hook the linkage to the car then hook the shifter to the linkage? help
lol thanks alot guys.
Chris
Chris
International TWIN ENGINE TWIN TURBO honda crx delsol AWD
urbanstyle
Nov 21, 2017 08:02 AM
Total_Package
17
Jun 22, 2005 01:18 AM
DaMmniTz
Oct 30, 2004 01:45 PM
