Installing a Brake Booster and MC?
Old May 10, 2007 | 02:11 PM
Sloshy's Avatar
Default Installing a Brake Booster and MC?
has any one done this, i search but just found stuff on changing Master Cylinder but i didn't really found much info on installing brake booster, so some one please enlighten me in this situation
Old May 10, 2007 | 02:26 PM
bmoua's Avatar
try finding a manuel bro, the MC is a breeze but the booster will alot harder since you'll have to go under the dash.
Old May 10, 2007 | 02:49 PM
Sloshy's Avatar
yeah that's what i though hopefully it's just the check valve ::fingerCrossed::
Old May 10, 2007 | 03:21 PM
jdmjaser's Avatar
Default Re: (Sloshy)
both really easy to put in..jus takes time
Old May 10, 2007 | 03:43 PM
Slurp56's Avatar
Default Re: (bmoua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">try finding a manuel bro, the MC is a breeze but the booster will alot harder since you'll have to go under the dash. </TD></TR></TABLE>
Going under the dash is a poor metric of difficulty.
Sure, slide the seat all the way back, then lay on the floor of the car, remove 1 cotter pin so the clevis pin can slide out, then remove 4 nuts.
Sounds pretty tough!
Old May 10, 2007 | 03:54 PM
EL Vap133's Avatar
Default Re: Installing a Brake Booster and MC? (Sloshy)
https://honda-tech.com/zerothread/642479
Old May 11, 2007 | 10:42 AM
Sloshy's Avatar
i checked the FAQ thread before i posted, there isn't anything on brake booster repalcement, unless i missed it all i saw was for master cylinder repalcement
88 EF Hatch
Dec 9, 2008 08:46 PM
MrMug3n
Aug 13, 2008 01:49 PM
LSej1
Apr 29, 2008 03:52 AM
supracrx
22
Dec 12, 2006 08:23 PM
MNCRXSi
Nov 1, 2006 06:49 PM
