How to test PCV Valve?
Old May 10, 2007 | 12:46 PM
stefan*'s Avatar
Default How to test PCV Valve?
Anyone? I don't want to swap it out if not necessary.
Mine is on a 1992 Accord EX-R
Old May 10, 2007 | 01:19 PM
chingerboi's Avatar
Default Re: How to test PCV Valve? (stefan*)
To test your PCV valve, you just un-plug it from your valve cover and shake it! If you hear a little rattle, then its fine. If you don't hear any rattle, then its time to buy a new PCV valve. I got this info from my 1990-1993 Honda Accord Haynes manual. But this method applies to all cars. Aight hope that helps, later.
Old May 10, 2007 | 02:31 PM
The-Kid's Avatar
Ditto to chingerboi's reply. Also if it's a little sticky or it rattles a little, you can take it off and clean it with a Carb cleaner. Just spray into the PCV. Replacing it is a good idea too.
Old May 11, 2007 | 06:36 AM
stefan*'s Avatar
Default Thanks!
Thanks guys! Appreciate the tip! Who would have thought it was that easy
91EF919
Jun 14, 2009 02:07 AM
itsjustmeME
Mar 30, 2008 06:18 AM
