loud squeek?
More likely it's your ac or power steering. Check and see if any belts are too tight/loose.
If your timing belt squeaked/jumped you'd notice a lot more than noise.
It could also be the dizzy bearings starting to go. My 93lx made intermittent squeaks at higher RPM, then more regular squeaks at high rpm, then regular squeaks at all rpm, then the dizzy was toast.
Bictorious
12
May 5, 2004 07:56 PM
