max wheel size for an 99si
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bonSI »</TD></TR><TR><TD CLASS="quote">trying to figure out the widest size rim i can fit on my car without it being to wide. plrobably 16-17" wheels. thanks</TD></TR></TABLE>
You can put 18's on there if you wanted to...but i would not reccomend it as it looks retarded. I have 17's and i rub every once in a while going over some bigger harsher bumps and dips...hind sight is always 20/20, that being said i wish i got some 15's maybe 16's if i liked the wheel enough.
a friend of mine had me try to put some 22's on his 07 accord, i think the stock tire size is 205/50/16 these were 255/40/22, yeah, it was funny.
back to your question, the width of the tire will be somewhat affected by how low you plan on running it as well, i ran 16's with 205/45/16's at one point, now i have 15's.
18s on a honda...
ideal width depends on offset and chassis prep.
If you flare the front fenders and do a tone of measureing to get the offset perfect you can squeeze a 7.5-8" in there but it's a shoehorn fit and you will not be able to turn the wheel all the way.
assuming you know that you'll have to roll the fender lips to do anything when lowered...
15x7s with a 42 offset fit great.
16x7.5 with a 38 offset will fit but you will have to 'adjust' the inner fender lining a little.
I don't know about 17's.
car is down ~2.25"
car is down ~2.25"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua »</TD></TR><TR><TD CLASS="quote">max for me would be 16's....the biggest you should ever go on a ej8/em1...17's...</TD></TR></TABLE>
x2
I prefer 15's and 16's... Just looks a lot cleaner
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 »</TD></TR><TR><TD CLASS="quote">I think some of us are hinking width and some of us are thinking circumfrence (sp)...
to the OP which is it?</TD></TR></TABLE>
i think u mean diameter not circumference...and i believe the op is talking about the width but i could be wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vipervenom6 »</TD></TR><TR><TD CLASS="quote">
i think u mean diameter not circumference...and i believe the op is talking about the width but i could be wrong</TD></TR></TABLE>
Correct diameter,
thanks i could not think of the right word
Correct diameter,
correct the width of the wheel to get the maximum contact witht the road. i dont want stupid big like 22", this will be an autocross car and im going for max grip. im going with 16-17 no bigger. sorry for the confusion
If you're going to autocross it and be serious about it, 14's or 15's.
16's if you want to bend a rim or lose sidewall flex.
17's or bigger and autocrossers wil laugh at you.
