B20v type r head/ gsr tranny
Old May 10, 2007 | 08:52 AM
zgodfathera's Avatar
Default B20v type r head/ gsr tranny
im plannin on buying a civic with a B20v type r head/ gsr tranny set up. now i really not too familiar with hondas too much more of a dsm guy usin it for a DD...
the questions i have are is it a good set up?
not sure if the block is a b20?
was the engine bay modified to fit that set up?
thanks for the help in advance!!!
Old May 10, 2007 | 09:16 AM
da_dude's Avatar
b20 vtec is the big dog for the b-series. It's a good set-up alright. There should be a engine code in the front of the engine where its mate with the tranny. It should say b20 on it if it is a b20. And the motor just drop in without modifing anything.
Old May 10, 2007 | 09:36 AM
Default Re: (turb20_vtec)
yeah thanks for the info pretty much gave me the stamp of a approval bro thanks
Old May 10, 2007 | 09:49 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (zgodfathera)
You'll need mounts, wiring etc.
Like any other b series.
Make sure not to rev the **** out of it because the b20's cylinder wall casting is crap.
If you want to do anything serious with it you'll need to build it.
Sleeves, pistons, rods etc etc.
Old May 10, 2007 | 09:58 AM
Default Re: (ek forever guy)
well i was actually lookin to buy this car but i havent had a chance to see it yet due to the guy not callin back...
so stock what is it able to rev to?
good info thanks bro
Old May 10, 2007 | 10:04 AM
Alex_G's Avatar
Occupy GDD
If the bottom end stock do not rev it past 7k. It will not last long if you do so, you'll
snap a rod bolt or even cause a spun bearing.
Old May 10, 2007 | 11:54 AM
Default Re: (Alex_G)
good to know thanks man...
Old May 10, 2007 | 12:28 PM
The Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alex_G &raquo;</TD></TR><TR><TD CLASS="quote">If the bottom end stock do not rev it past 7k. It will not last long if you do so, you'll
snap a rod bolt or even cause a spun bearing.</TD></TR></TABLE>
my friends car revs to 9k with a stock b20 bottom end also making 204whp on a dyno not dynojet, with a built head for the past 8 months , no problems yet
its all in your builder and a good tune , then you can beat the crap out of it ..
honing and balancing the block will also help, also getting a girdle and block guard will also help you rev to 9k no prob, + you got typeR valves
Old May 10, 2007 | 01:36 PM
da_dude's Avatar
Just troque your rod bolts to 35 ft pound and you should be good. That is what my cousin did on his b20 vtec and been revving the living **** out of it to 9K. If you know what you are doing it should be fine. But now his is the processes of his high compression b20 vtec.
Old May 11, 2007 | 07:24 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheSi &raquo;</TD></TR><TR><TD CLASS="quote">
honing and balancing the block will also help, also getting a girdle and block guard will also help you rev to 9k no prob, + you got typeR valves </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turb20_vtec &raquo;</TD></TR><TR><TD CLASS="quote">Just troque your rod bolts to 35 ft pound and you should be good. That is what my cousin did on his b20 vtec and been revving the living **** out of it to 9K. If you know what you are doing it should be fine. But now his is the processes of his high compression b20 vtec.</TD></TR></TABLE>
how often are they being revved that high? constant abuse like that will lead to something breaking.
Old May 12, 2007 | 09:17 AM
da_dude's Avatar
Default Re: (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">
how often are they being revved that high? constant abuse like that will lead to something breaking.</TD></TR></TABLE>
Well, he doesn't revved it all day. He just drives it more aggressive the your nornmal driving style. He even took it 10K a couple of times.
Old May 12, 2007 | 09:24 AM
Ek Forever y0!
Well, he doesn't revved it all day. He just drives it more aggressive the your nornmal driving style. He even took it 10K a couple of times. </TD></TR></TABLE>
Tell him it probably doesnt make power past 7500. He's retarded.
Old May 12, 2007 | 12:37 PM
da_dude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">
Tell him it probably doesnt make power past 7500. He's retarded. </TD></TR></TABLE>
We all know that already. That is what I kept telling him. But he just like to do it just for the heck of it.
rafig2001
Sep 24, 2010 09:52 AM
integraboi2626
Aug 29, 2006 06:55 PM
iluvsleepers
11
Nov 9, 2003 06:03 PM
JSTOCK
Aug 9, 2002 05:07 PM
kmf0211
Jul 16, 2002 11:06 AM
