MY CAR WONT GO INTO GEAR AFTER START UP...
MY PRELUDE WONT GO INTO GEAR AFTER START UP....I HAD CHANGED THE SLAVE CYLINDER AND THE MASTER CYLINDER AND BLED BOTH. IT RAN FINE FOR A FEW DAYS THEN IT STARTED HAPPENING AGAIN...WHAT NOW???
Check your brake fluid when I first got my prelude I drove 600 miles and forgot to check the brake fluid... You might have to drain out the air from your clutch first but sounds like pumping the clutch for a bit will do the work.
allmotor.net
May 23, 2004 08:53 PM
B16A2-EM1
45
Feb 7, 2003 01:55 PM
