How does my prep work look for paint?
Old May 10, 2007 | 12:45 AM
JDM-EJ1's Avatar
Default How does my prep work look for paint?
This was my first time sanding down a car, and getting it ready for paint. The car is very smooth and has no bumps or dents in it at all. Please tell me how my prep work looks:
Old May 10, 2007 | 01:10 AM
NrG's Avatar
NrG
it's really hard to tell by pictures. good prep work is all by feeling the surface
Old May 10, 2007 | 02:28 AM
Lasty K's Avatar
Nice set of stickers on the windshield
Old May 10, 2007 | 04:48 AM
HONDA RR's Avatar
Default Re: (NrG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NrG &raquo;</TD></TR><TR><TD CLASS="quote">it's really hard to tell by pictures. good prep work is all by feeling the surface </TD></TR></TABLE>
Old May 10, 2007 | 04:49 AM
Phil DeVtec's Avatar
Default Re: (NrG)
Absolutely.
Old May 10, 2007 | 06:29 AM
Genuine Rolla's Avatar
it looks alright. what did you use to wetsand..? What color are you going with..?
If thats the primer (and i'm assuming it is) it looks really dark to be painting light colors on it. Like the guy who posted said...its all by the way it feels.
Old May 10, 2007 | 06:39 AM
JDM-EJ1's Avatar
Default Re: (Lasty K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lasty K &raquo;</TD></TR><TR><TD CLASS="quote">Nice set of stickers on the windshield</TD></TR></TABLE>
You fail at life. Stop breathing.
Awesome. It's really smooth when I run my hand across it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Genuine Rolla &raquo;</TD></TR><TR><TD CLASS="quote">it looks alright. what did you use to wetsand..? What color are you going with..? </TD></TR></TABLE>
I'm getting it sprayed black.
Old May 10, 2007 | 06:56 AM
CBURKE's Avatar
Well, just so you know black it the hardest color so paint, reason is it shows every flaw. You are going to want to go over the car with a wet 400 then a wet 600 if you cut through then you will need to primer that spot again. Make sure any body work you did it feathered really good or it will show up in the paint.
It is hard to tell from a pic but it looks to be ok. What is the tape over the holes for?
Old May 10, 2007 | 08:05 AM
JDM-EJ1's Avatar
Default Re: (CBURKE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE &raquo;</TD></TR><TR><TD CLASS="quote">Well, just so you know black it the hardest color so paint, reason is it shows every flaw. You are going to want to go over the car with a wet 400 then a wet 600 if you cut through then you will need to primer that spot again. Make sure any body work you did it feathered really good or it will show up in the paint.
It is hard to tell from a pic but it looks to be ok. What is the tape over the holes for?</TD></TR></TABLE>
Cut through? What do you mean? Cut through the original coat of primer?
I keep my car parked outside, since there is no moldings on the car; the tape is to prevent water from getting in there.
Old May 10, 2007 | 08:16 AM
b16ej1lsd's Avatar
take that blue tape off the outside of the molding holes and tape them off from the inside.
Old May 10, 2007 | 08:17 AM
BLANCOh22a4's Avatar
Default Re: How does my prep work look for paint? (JDM-EJ1)
is that a rear fog light cutout?
b16ej1lsd's Avatar
the best way to check how straight a panel is before paint it to wipe it all down with pre-clean so the panel is real wet with it and the reflection off that will give you a good idea what your working with.
Old May 10, 2007 | 08:19 AM
b16ej1lsd's Avatar
oh and btw, atleast take off your mirrors, door handles, rear lights and and roof moldings. They are easy to get off and will save you alot of time when you go to tape it up. You should have the quarter, back and front glass all taken out too because those moldings are almost impossible to tape off, especially the quarter glass.
Modified by b16ej1lsd at 11:33 AM 5/10/2007
Old May 10, 2007 | 08:48 AM
CBURKE's Avatar
Default Re: (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
I keep my car parked outside, since there is no moldings on the car; the tape is to prevent water from getting in there.</TD></TR></TABLE>
Yes sanding through the primer.
Old May 10, 2007 | 11:26 AM
JDM-EJ1's Avatar
Default Re: How does my prep work look for paint? (BLANCOh22a4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLANCOh22a4 &raquo;</TD></TR><TR><TD CLASS="quote">is that a rear fog light cutout?</TD></TR></TABLE>
Yes.
Thanks for all the tips guys.. Anything else?
Old May 10, 2007 | 02:20 PM
Agent_EM1's Avatar
As long as its all smoothe shoot the spray
Old May 10, 2007 | 06:28 PM
JDM-EJ1's Avatar
Default Re: How does my prep work look for paint? (Agent_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agent_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">As long as its all smoothe shoot the spray </TD></TR></TABLE>
Good to hear. Thanks.
dj27nitro
Nov 5, 2017 06:42 AM
xRacerX81
Paint and Body
21
Jun 9, 2008 02:35 AM
Joey.
Nov 14, 2007 11:12 AM
cgscivic
Jan 14, 2005 06:09 PM
sutrusu
Jun 23, 2003 08:17 AM
