My custom cf gauge cluster......
UPDATE ON PAGE 2
well here's what i came up with..... i don't have a blower motor/heater core and this is not my daily so.....
Started like this....
Laid some CF over it....
And got this....
Basically done, just need to clean it up after it dries.
Doesn't look to sturdy, but its alot sturdier than i expected.
I put a few screws to hold it in place but you cant see um!
Liquid Nails extra duty construction 4x strength stuff. Just to make sure!
CF o CF how i love thou
Modified by mitsuman at 3:30 PM 5/12/2007
And got this....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alex Trebek »</TD></TR><TR><TD CLASS="quote">wtf did you put around the edges? poop?</TD></TR></TABLE>
inside or outside?
inside-heavy liquid nails, outside-black caulking
inside or outside?
LOL!
LOL!
when you caulk do a tinny bead then wipe it with a mosit rag it will only stay in the cracks and then look supper clean. pull that caulk off and redo that part
other then that
other then that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bulletspastsunset »</TD></TR><TR><TD CLASS="quote">the caulking on the outside killed it</TD></TR></TABLE>
verrry much!!!
verrry much!!!
ya i tried that but i put screws in the corners to hold it in place and i wanted to cover them. there tiny but they show if there is less in the corners, and i didnt want to leave it all fat in the corners and all skinny for the rest. I will probable redo it if i cant clean it up as well as i want to.
very good work
....but
....but<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bulletspastsunset »</TD></TR><TR><TD CLASS="quote">the caulking on the outside killed it</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DUFFM4N »</TD></TR><TR><TD CLASS="quote">very good work
....but</TD></TR></TABLE>
Ya, the more i look at it the worse it gets. Check back for updates on the caulking
Thanks for the opinions both
and
....but</TD></TR></TABLE>Ya, the more i look at it the worse it gets. Check back for updates on the caulking
and
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goldegg »</TD></TR><TR><TD CLASS="quote">Looks like carbon fiber tape, and those lights are ugly as hell.
I don't know if you could of found an uglier light.</TD></TR></TABLE>
Yes it is a slab of CF .2mm thick stuck onto plaxi glass. I like the lights, i need to see them lite before i complete the install. If they look bad, i will put te switches there. This is what it looks like with the switched in instead.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Setup »</TD></TR><TR><TD CLASS="quote">looks like ***** with the cocking on the outside.</TD></TR></TABLE>
Thinking too much of male genitalia?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DUFFM4N »</TD></TR><TR><TD CLASS="quote">is it a possibility to remove the caucking from the front and just mold it from the back like how u did?</TD></TR></TABLE>
Haha it does look good until all the crap on the outside showed up
