rear disk converstion question
got the same issue.... i did a search and a whole thread showed up.... matco sells the tool to remove/install the trail arm bushing without removing the arm...
good luck i still have do mine, but dont want to spend the loot for the tool.... i might just use my air hammer...
Autozone doesnt have the right tool for rent.
Napa autoparts store/machine shop charged me $20 to remove and press in new ones
Save yourself from trying to take them on or off the car its a PITA...just take off the trailing arms and take it to your local machine shop
If you have the trailing arms taken off, removing the old bushings is VERY easy. You just hit them with a hammer. It's a taper fit, which means that its not like a normal press fit. Once you break the friction of the taper fit, they just pop out.
Same with installing new ones...just hammer on the edge of the bushing until it's seated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL-MoToR559 »</TD></TR><TR><TD CLASS="quote">wait, correct me if i'm wrong...dc2 teggy's disk brakes would not fit on an ef</TD></TR></TABLE>
You are wrong. DC2 ('94-'01) Teggy rear discs bolt right up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickrps »</TD></TR><TR><TD CLASS="quote">
You are wrong. DC2 ('94-'01) Teggy rear discs bolt right up.</TD></TR></TABLE>
Correct!
Correct!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djphonics »</TD></TR><TR><TD CLASS="quote">If you have the trailing arms taken off, removing the old bushings is VERY easy. You just hit them with a hammer. It's a taper fit, which means that its not like a normal press fit. Once you break the friction of the taper fit, they just pop out.
exactly what i did
</TD></TR></TABLE>exactly what i did
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickrps »</TD></TR><TR><TD CLASS="quote">You are wrong. DC2 ('94-'01) Teggy rear discs bolt right up.</TD></TR></TABLE>
What about DC2 front knuckles?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hafftrak »</TD></TR><TR><TD CLASS="quote">
What about DC2 front knuckles?</TD></TR></TABLE>
You would need to use DA knuckles and swap the DC2 brake hardware on them. I did this on my CRX and I love the results!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hafftrak »</TD></TR><TR><TD CLASS="quote">Do the DC2's have bigger calipers? From what i could find the rotors are the same size.</TD></TR></TABLE>
Bigger calipers as opposed to what?
sk8board{Pete}
Oct 22, 2008 09:17 AM
shaggyeg6si
Jun 7, 2008 11:32 AM
alscrx
11
Mar 26, 2008 02:31 PM
