car not running right
Old May 9, 2007 | 07:01 PM
90civSi's Avatar
Default car not running right
a little background on the situation, i have a 90 hatch Si, i swapped a b16 in OBD0 and it ran fine. then i blew the differential and had to swap transmissions. When i got done swapping the new tranny on we had to jump it cuz the battery was dead. One of the ground on the battery wasnt connected and it arched. When i went to drive it it would not go past 3500 rpm sounded almost like it was boggin but just stays at 3500. If you are in neutral and hold the pedal to the floor it will go up to 6000 and come back down to 4000 and just stay there. I replaced the ecu and nothing, the resister pack nothing.
i just saw today that my i am throwing my tps code but the cell on the dash doesnt pop up. what else could be causing the engine to do this?
Old May 10, 2007 | 05:12 AM
90civSi's Avatar
bump
Old May 10, 2007 | 06:51 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: car not running right (90civSi)
You probably should try to clear that TPS code up. The light in the cluster for the CEL simply may have burnt out . I'd try testing your TPS to see if it's within the proper voltage. Good luck, electrical demons are the worst.
Old May 10, 2007 | 06:57 AM
90civSi's Avatar
Default Re: car not running right (wiZCo)
well i know the cell isnt burnt out on the dash, what is the proper voltage suppose to be on it i wanna say something like 1.5 but im not to sure anyone know?
Old May 10, 2007 | 02:02 PM
90civSi's Avatar
bump for anyone that has any kind of experience with this or anything at all
Old May 10, 2007 | 06:53 PM
90civSi's Avatar
bump
Old May 11, 2007 | 01:47 PM
90civSi's Avatar
bump
Old May 12, 2007 | 12:21 PM
90civSi's Avatar
bump
Old May 12, 2007 | 12:29 PM
Janos Lin's Avatar
Default Re: (90civSi)
0.45-.5 at throttle closed, 4.5 wide open.
Janos
Old May 18, 2007 | 01:41 PM
90civSi's Avatar
ok i checked the voltage at my tps at it was 0 and i would adjust it and it would read 1, so im thinkin my tps is toast so what tps sensors can i use on an obd0 b16?
Old May 18, 2007 | 02:21 PM
MEBHB91EF9's Avatar
any b-series tps would work jsut fine, had to replace mine when i did my swap
Old May 18, 2007 | 02:26 PM
91_Civic_Hatch's Avatar
Default Re:
Did you swap the two wires on the tps? I had to do this to mine.
Old May 19, 2007 | 09:05 AM
90civSi's Avatar
is it true that you can also use obd0 D series tps sensors?
so i can just try to find one for my cars original motor?
Old May 19, 2007 | 11:53 PM
It looks as though a D series would fit, but I'm not totally sure on that. I looked at my D series and my B series and they look the same. I would try to find one for free or for cheap and see if it works.
Old May 20, 2007 | 09:50 AM
90civSi's Avatar
well if anyone has a TPS i can buy pm i would really like to get my car driveable haha its been to long. thanks
Old May 20, 2007 | 01:04 PM
How much you wiiling to pay for one? I'll sell you the one I have off my D series. Shipping will me $8.10. Let me know.
NIKADEM0
Jul 28, 2014 08:59 AM
90civSi
May 18, 2007 01:40 PM
Si Jeff
27
Dec 20, 2005 05:34 PM
Powered By Garrett
Dec 17, 2005 04:55 PM
ThefirstPACT
Dec 20, 2003 12:26 PM
