Big problem with d16 motor.... Be Creative...
Old May 9, 2007 | 06:55 PM
hondastrtracr's Avatar
Default Big problem with d16 motor.... Be Creative...
Well Today cruisin around and comin up to speed after a stop light... I hear a really loud ticking noise... Valve Lash! The worst ever! Well Come home pull the valve cover off and the one of the intake valve adjustment screw lock nut is missing with the screw backed out... well i am almost certain that nut went down into the oil pan it did not drain out either... so right now im screwed cuz i dont wanna drive it with a chunck of metal floatin around in there... any suggestions other than the obvious pull off the oil pan?
Old May 9, 2007 | 07:04 PM
Mr.EM1_EK's Avatar
Default Re: Big problem with d16 motor.... Be Creative... (hondastrtracr)
the safe way is to drop the oil pan, may find some other suprises in there, you never know. you could try to stick a magnet pen through the drain hole, i doubt it will work though. or get a piece of magnet, stick it on the oil pan and slide it around until you grab it and pull it through the drain. just trying to be creative like you said.
Old May 9, 2007 | 07:08 PM
vi3tromanc3r's Avatar
you can try going around with a telescopic magnet to pick it up, thats what i do in school when we working on a motor and some metal piece falls in.
Old May 9, 2007 | 07:32 PM
Default Re: Big problem with d16 motor.... Be Creative... (vi3tromanc3r)
is the bottom of the oil pain flat or is there different cavities in there that it can get stuck in? I can go pick up a magnet cuz that one i have would not fit through the drain hole.
Old May 9, 2007 | 08:07 PM
Mr.EM1_EK's Avatar
i think the stock one is flat
Old May 9, 2007 | 10:03 PM
Another question is where else could it have gone? The drains in the head all lead to the oil pan? Am I right?
nrraiders35
May 16, 2013 12:00 PM
realis9
Sep 18, 2008 06:53 PM
Nocture
Jul 21, 2008 10:12 PM
bluecb7
Mar 28, 2004 03:46 AM
bluecb7
Mar 14, 2004 04:51 PM
