Gas pump stops prematurely before tank is full
Old May 9, 2007 | 04:23 PM
slomob18b's Avatar
Default Gas pump stops prematurely before tank is full
Car is a 1998 Honda Accord 4dr LX automatic w/ ~106,000 and maintenance is very up to date. Does anyone experience gas pumps clicking off prematurely when they try to fill up at gas stations? The gas gauge is almost at empty and while I am fillling up, the pump clicks off like it is full, but I have only pumped in a couple of gallons. This happens at every gas station I have been to with some stopping earlier than others. It has happened for a while now and its more annoying than anything. Anyone have the same experience of solution to this?
Old May 9, 2007 | 05:17 PM
funtak's Avatar
Default Re: Gas pump stops prematurely before tank is full (slomob18b)
Fuel gauge could have problems. Does the miles per trip match up to before this problem happened?
Old May 9, 2007 | 05:25 PM
slomob18b's Avatar
Default Re: Gas pump stops prematurely before tank is full (funtak)
Yes they match because I always keep track of my miles per gallon/tank so the gauge should be reading accurately.
Old May 9, 2007 | 05:40 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
I don't have this problem with my Accord; but, had this problem on one of my other cars before. My friend showed me to pull the top of the rubber part a little bit away from the car, so the vacuum wouldn't stop the fuel from dispensing from gas nozzle. A little bit of hassle, but it worked.
Old May 9, 2007 | 07:01 PM
slomob18b's Avatar
Default Re: (tech8)
I have tried it that way as well. The pump fits snug onto the hole, but it still stops prematurely.
Old May 9, 2007 | 07:45 PM
JimBlake's Avatar
Default Re: (slomob18b)
There's a couple vent lines alongside the filler pipe in the fender. Probably have to remove a shroud that protects them from rocks & stuff. Check them out & look for anyplace where they're pinched or kinked or something like that.
Old May 9, 2007 | 08:14 PM
slomob18b's Avatar
Default Re: (JimBlake)
Cool, I'll check that out tomorrow, thanks.
Old May 10, 2007 | 08:28 AM
flight50's Avatar
i had this problem before. turned out to be the pump handle prematurely stopped. so i held the handle by hand once it stopped and lifted it up instead of letting it rest on its own.
Old May 16, 2007 | 04:11 PM
slomob18b's Avatar
Default Re: (flight50)
Everytime I pump I always hold the handle down manually. Either way it still stops prematurely. Just replaced the gas cap, but don't think that should affect anything.
Old May 21, 2007 | 04:37 AM
kllee94's Avatar
i have a 98 accord that does the same thing, i am putting it in the shop for various reasons this week so ill let u know what i find out
Old May 21, 2007 | 10:08 AM
ilovemydc5's Avatar
Default Re: Gas pump stops prematurely before tank is full (kllee94)
maybe u got the gas nozzle in to deep an it thinks its full when u do it had the same problem with mine pull it out a little then full it up then it will click when its almost full.
Old May 24, 2007 | 10:20 AM
flight50's Avatar
Default Re: Gas pump stops prematurely before tank is full (96Accordh22)
kinda similar to what i was saying. i have had a few in too deep and readjusted the handle by holding it up my self while pumping. some pump are picky and/or are going out. if every pump you go to does the same thing, then its some with your car.
Old May 24, 2007 | 05:28 PM
hondadude's Avatar
There is a service bulletin about this problem...vent valve is inop.
Old May 25, 2007 | 03:34 AM
slomob18b's Avatar
Default Re: Gas pump stops prematurely before tank is full (hondadude)
If it is bad, would the check engine light be on?
akshn1
Apr 13, 2012 10:27 AM
ClarkRU
Feb 23, 2010 10:52 AM
dirtyhalo
Jun 2, 2005 02:25 PM
Gangsta Accord
Jun 22, 2002 05:47 AM
