parking lights and city lights on all the time like day time driving lights...
Old May 8, 2007 | 07:53 PM
thareddb's Avatar
Default parking lights and city lights on all the time like day time driving lights...
Does anyone know how I would wire up my parking lights on my 93 eg si to always be on when the car is on... I want my city lights side markers and parking lights on all the time... any help would be great I looked around some but couldn’t find any thing specific with a pictures
Old May 8, 2007 | 07:55 PM
Jhonny Ricer's Avatar
Default Re: parking lights and city lights on all the time like day time driving lights... (thareddb)
why can6t you just turn them on whenever you have the car on
Old May 8, 2007 | 07:57 PM
thareddb's Avatar
cuz that gets anoying and i dont want to have to do that every time and why do that when it can be wired to just turn on when the car turns on????
Old May 8, 2007 | 08:01 PM
thareddb's Avatar
on my 90 integra i was able to wire my fogs to stay on all the time buy just leaving the buton down and then wiring one wire from the fog switch to the rear defroster switch cand i doo somthing simular in my eg
http://www.g2ic.com/tegtips/lighting/1.html
Old May 8, 2007 | 08:14 PM
yea id say find a constant 12volt source somewhere inside and tap into it with a wire run that wire to a constant pulse switch then run it out down to each of your corners here you spliced in the city lights attach the power from the switch there and run it along the radiator support to the other side and splice the wire into wher your city light is spliced in over ther as well than whenever you flip the switch it will override the relay and light up your city and corners and they can be on constantly thats how i would do it at least ahope it helps
Old May 9, 2007 | 10:07 AM
thareddb's Avatar
any diy's
Old May 11, 2007 | 09:20 PM
phoebs's Avatar
how sluggish!
I wont always turn my GM parking lights on when the car is on. That would be a waste in the battery. Besides I might be violating some traffic guidelines or something like that.
Old May 11, 2007 | 10:06 PM
Default Re: parking lights and city lights on all the time like day time driving lights... (phoebs)
Um if your car is running that is not a waste of battery since everything is powered by your alternator after initial startup ... And no way in hell that is violating a traffic law since DRL were introduced and all lights are always on while the vehicle is running.
to the OP, As for your DIY there are none that I can find DIY all I can tell you is go with like the 12v ignition wire for your HU and run an inline fuse after that therfore if you leave the switch on and turn off the car the lights go off automatically, Place a switch somewhwere like by your E-brake or something or just hide it to a reachable place so you still have the option of turning them off then run the wire through your firewall to one of your headlights the turn signal harness should have 3 wires one is constant 12v, one is blinker, and one is ground. red and green is your constant, red and black is your blinker, black is your ground tap your 12V power into the constant 12V and do the same on the other headlight turn on accesories and your city/corneres should be on
Old May 11, 2007 | 11:34 PM
thareddb's Avatar
Default Re: parking lights and city lights on all the time like day time driving lights... (Jhonny Ricer)
sweet ima do it when i have time maybe tomorrow after work thanks for the help
j.packsb
Mar 2, 2010 05:54 AM
Whatislove
Honda Civic (2001 - 2005)
Nov 27, 2008 10:13 PM
racehesh
11
Jul 15, 2007 07:36 PM
