si headswap car wont start
my buddy blew a headgasket on his dx ef and decided while taking that head off why not upgrade to an si head. i did the wiring for him and its fine, there are no issues with it. when going to start the car we get CEL 8 sometimes. the car also wont start, it cranks gets fuel and spark but just doesnt start. we eventually got the car to start and turned it off then filled it up with oil and it wont start again, it tries to idle but dies out very quickly. it seems like its a timing issue, i dont know if the engine throwing the TDC code would prevent it from starting. we checked timing again and again and it seems fine but it aparently isnt. appreciate any help.
try to ajust the idle or mabe when you put the distributor on its off 180 degrees r u sure its getting fuel? are spark plugs g0od? are all the wires connected correctly in right firing order? not sure i would have to l0ok at it but go over everything carefully and inspect everything again
yeah when i clear the codes it doesnt come up again until its starts but it doesnt stay started like itll die as soon as it starts. i forgot about flipping the dizzy ill have to try that out. but im 100% possitive the wirings right as ive checked it several times now. all the grounds are connected. i really dont want to check the timing again but ill check that out. that would be funny if it was that ef relay that likes to be stupid
i did all the wiring yeah. im fairly certain its something with either the timing or maybe that main fuel pump relay, but it wouldnt get fuel if it was that. its strang when its cranking itll sound like it starts and itll just instantly die out
Well, code 8 is for the TDC sensor in the dizzy, so you may still have a problem with the wiring, or the dizzy itself. Not sure on this, but when converting to MPFI can you not use the DPFI dizzy?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">Well, code 8 is for the TDC sensor in the dizzy, so you may still have a problem with the wiring, or the dizzy itself. Not sure on this, but when converting to MPFI can you not use the DPFI dizzy?</TD></TR></TABLE>
You can actually use the DPFI dizzy, you just won't get the crank position and you'll have to remove teeth from one of the other gears (I forget which, but one of the MPFI swap guides on google has that info in it). It will run like ****, but you would be able to get it running. Without modifying one of the gears in the dizzy, it won't work (my understanding at least).
I think that you have to set the cam timing differently if you use an Si head. The camshaft is physically different and has a different set of timing marks to line up with (at least on the Si block). If you have a service manual, you might check that out.
im using the si dizzy not the dual point one, im not sure what head he put on it either, its not vtec so im going to go with a6 head. im going to check over the timing for si's. if timing was off would it throw the TDC code?
sohcVTEK
Jun 18, 2006 08:44 PM
bonestock92si
38
Aug 30, 2004 10:02 PM
