Quick question- rear brake pad change
Old May 8, 2007 | 05:43 PM
Utilitarian's Avatar
Default Quick question- rear brake pad change
I'm getting new pads tomorrow and changing them after work with limited light. So, I was looking at the rear caliper and it appears the dust shield has to come off, then perhaps the caliper can be popped off after the two bolts are removed?
Does this sound right? I don't think there's enough clearance to just swing it back like the front though.
tia ,
Matt
Old May 8, 2007 | 05:54 PM
cltitus's Avatar
Default Re: Quick question- rear brake pad change (Utilitarian)
going to have to use a wrench to get teh dust cover off pain in the ***. Then the 2 bolts for the caliper bolts and it should come right off replace the pads and blam unless theres seized bolts no worries
Old May 8, 2007 | 06:18 PM
Default Re: Quick question- rear brake pad change (cltitus)
Is there any easy way (without the special tool) to get the piston to retract? I've read you have to twist it back in whereas the fronts you can just toss the clamp on it.
Old May 8, 2007 | 06:23 PM
cmdr430's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Utilitarian &raquo;</TD></TR><TR><TD CLASS="quote">Is there any easy way (without the special tool) to get the piston to retract? I've read you have to twist it back in whereas the fronts you can just toss the clamp on it.</TD></TR></TABLE>
screw driver works.....
Old May 8, 2007 | 06:24 PM
totsie7944's Avatar
dude i just got a big paint scraper kinda thing like a big screw driver and screwed it in lol....took like 10 mins to change back brakes... good luck man
nsxtasy
May 9, 2006 05:45 PM
sleepyhamsterlx
Dec 29, 2003 03:12 PM
Heinz57
May 18, 2003 06:18 PM
BrandonClaps
Jun 27, 2002 01:36 PM
