Clutch pressure
Old May 8, 2007 | 05:19 PM
clkio's Avatar
Default Clutch pressure
My clutch is starting to feel a little wired. The clutch pedal is very high (all the way to the top), is th clutch starting to go? When the car is kool, the pedal is fine, its only when the car is being driven for like 15 minutes or so, then the pressure is all the way at the top (just tap on the clutch and it responds)
Old May 8, 2007 | 05:26 PM
97Ej6mike's Avatar
Sounds like some simple expansion\contraction laws of phsyics due to heat. You may be low on fluid and have airbubbles in your line, which would allow for that to happen. Have someone you know thats experienced, a Mechanic, or even DIY, add fluid and bleed the system for you.
Old May 8, 2007 | 05:29 PM
clkio's Avatar
Default Re: (97Ej6mike)
I kinda guessed that it would be either fluid or clutch going old, i am gone try to search and do it myself, is it like bleeding the brakes?
Old May 8, 2007 | 05:30 PM
clkio's Avatar
Default Re: (clkio)
BTW: i drive a 94 si
89sparks
Honda Motorcycles
May 24, 2020 05:27 AM
[713]
Jun 20, 2009 08:23 PM
LShatchie
25
Sep 1, 2005 06:03 PM
B18EG6
Feb 20, 2005 07:16 PM
Kermit EK
Jan 29, 2003 03:02 PM
