FS: TWM 50mm Individual Throttle Bodies B16, B18C5
TWM 50mm Throttle bodies for B16 and B18c R cylinder heads. They come with the fuel return line with earl fitting to work with OEM hard line.
RC 440cc injectors, Carbon Fiber Air Horns, T.P.S. plug with wires already installed in correct position ( just solder into factory harness).
As you will see in the picture I have blocked off the TWM mounting position for the M.A.P. sensor and tapped in vacuum fitting in the manifold.
I then made a vacuum block that will accept a OEM MAP sensor and fittings to attach to the manifold and be mounted remotely ( I Drilled holes in the wiper cowl / firewall to mount it and extended the MAP harness wires).
I DID THIS TO KEEP THE MAP SENSOR FROM SEEING UN-EVEN CYLINDER PULSES, IF YOU LOOK AROUND MANY PEOPLE HAVE DONE AND/OR RECOMMENDED THIS RETRO-FIT.
I bought these brand new for $1650 shipped
I AM SELLING THEM FOR $1500 SHIPPED WITH EVERYTHING NOTED ABOVE!!
If you have any question P.M. , E-mail, Or call (812-449-8139)
killacam661
11
Dec 2, 2007 04:41 PM
93civiccxhatch
Nov 6, 2004 06:37 PM
8124498139, b16, b18c5, bodies, ek, honda, independent, individual, map, mount, remote, sale, sensor, throttle, twm
