car wont start, need help
ok i originally posted this in the engine tech forum but have got no responses in two days. a few days ago i changed the clutch in my car and when i went for a test drive it ran perfectly and felt good. i dropped gears to see how it feels with the new clutch and all the lights came on (check engine, maintence req, oil, etc.) the car just died.i pulled the car over and tried restarting it, but it only cranks over but doesnt start. i assumed it was just a sensor we forgot to plug in or that popped out when i down shifted, but i re-checked and all the sensors were plugged in. we also pulled the spark plugs out and they werent igniting. any help would be greatly appreciated
-nick
btw i went to autozone to get a ecu scanner to check the codes but they dont have them for obd 1, does anyone know how i could check the codes?
-nick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo_ls_69 »</TD></TR><TR><TD CLASS="quote"> i will check the coil pack, but how will i know if it has gone bad? </TD></TR></TABLE>
Once you get to the coil, you will be able to see its output... I had a friend hold a sparkplug wire that was still connected to the plug/motor about an inch from the coil's output while I turned the engine over. There was no arc between the two, which lead us to believe the coil was toasted. If you remove the coil, you can also use a muti-meter to test the coil; however I am unable to provide instructions on this.
what do you mean check the distributor? i just changed the coil in it, wires, and plugs is there something else i should check along these lines? i am also checking the ecu codes tmw morning.
Yea it sounds like the dizzy to me.
When my timing belt went bad it did the same thing. The first thig we checked for was the dizzy. But unfortunately it was the timing belt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bonestock98GS »</TD></TR><TR><TD CLASS="quote">Yea it sounds like the dizzy to me.
When my timing belt went bad it did the same thing. The first thig we checked for was the dizzy. But unfortunately it was the timing belt.</TD></TR></TABLE>
so you mean to change the whole distributor? even after i changed the coil? there is somethin else that could have gone bad within the distributor, and is there a way i could check that stuff?
When my timing belt went bad it did the same thing. The first thig we checked for was the dizzy. But unfortunately it was the timing belt.</TD></TR></TABLE>so you mean to change the whole distributor? even after i changed the coil? there is somethin else that could have gone bad within the distributor, and is there a way i could check that stuff?
bump i just replaced the distributor with a brand new one, still no spark. and when i checked the ecu for codes nothing happened the CEL light just stayed on. does anyone have any other ideas of what could be wrong, im stumped and need to get this running
have you check for fuel pressure?did the new distributor came with a new igniter or did you use the old one? also check you fuses with a test light, also does the car turn over but dont start or it just doesnt do anything at all.
im gettting fuel, i can smell it on the spark plug when i pull it out. as far as the distributor with the igniter i just got a new complete distributor and swapped that over. i didnt transfer anything from either distributor
Alexander Smets
Jul 3, 2019 09:21 AM
headrec*
Apr 4, 2013 08:28 PM
Pworld925
Dec 31, 2011 12:24 PM
