header vs. oem manifold
Ok, so i just went underneath my car to change the oil ad i noticed my dc header is dented really really bad (like v shaped), so i was wondering if i should put back on my oem manifold and would this take away any performance?
also I was thinking of running a straight pipe from the manifold all the way back into a stock rsx type s muffler. is this a good setup?
Take pictures, let us see how bad the dent is. But if it's as bad as you say, you're probably losing some power with a dent. I don't know if going back to OEM would be better. So take pics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94lspower »</TD></TR><TR><TD CLASS="quote">Those dents aren't that bad, you would still have more power with the dent tha stock, so yea, i think u should stay with the DC</TD></TR></TABLE>
i agree, what are loosing half a horse power? who cares, keep it on
well tomorrow im pulling down the oil pan to change it, so i just want to know if i should change to the stock manifold on one time, guess i'll keep my dc. btw does the 4-2-1 header have more ground clearance?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sikhatch »</TD></TR><TR><TD CLASS="quote">well tomorrow im pulling down the oil pan to change it, so i just want to know if i should change to the stock manifold on one time, guess i'll keep my dc. btw does the 4-2-1 header have more ground clearance?</TD></TR></TABLE>
while your at it, get the oil pann tapped for a oil return
then you wont have to worry about that header anymore and just get a dp. dp= turbo!!!!
esurds
Aug 4, 2009 04:28 AM
hunter819
Oct 5, 2005 04:35 AM
, you are probably losing alittle bit of power but i'm pretty sure it would be better than stock most likely.
