CODE 20 Electrical Load Detector
Old May 8, 2007 | 11:14 AM
EGLUVN's Avatar
Default CODE 20 Electrical Load Detector
I have a buddy with a 90 Si hatch with a jdm b16a obd0. He is getting a code 20 which is electrial load detector. What the hell is that?
Old May 8, 2007 | 01:15 PM
mahatma's Avatar
Default Re: CODE 20 Electrical Load Detector (EGLUVN)
it's integrated into the underhood fusebox.
supposedly the only way to fix it is replace the fusebox.....???
Old May 8, 2007 | 05:28 PM
blah13's Avatar
Default Re: CODE 20 Electrical Load Detector (mahatma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">it's integrated into the underhood fusebox.
supposedly the only way to fix it is replace the fusebox.....???</TD></TR></TABLE>
Thats how I got rid of mine. I dont know what causes it, out of the 3 swaps I've done it only happened to one, and it was on the first crank after the swap.
Old May 8, 2007 | 07:33 PM
Crx Jimmy's Avatar
Default Re: CODE 20 Electrical Load Detector (blah13)
What ecu are you using? the pr3 and pwo do not look for the load detector, in fact you use the wire that went to that pin in the ecu for something else. so if you wired the car for vtec and have the stock si computer it will throw the code, the pr3 and pwo do not have that function so you have other problems
Old May 9, 2007 | 11:38 AM
EGLUVN's Avatar
It is the pr3 ecu. So i dont know whats up.
ludesrv
13
May 12, 2007 12:18 PM
xkagax
Jan 12, 2006 09:29 PM
Chris_
Sep 24, 2001 05:17 PM
