Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
k20a2 cams in k20a3?
Old May 8, 2007 | 07:11 AM
PasswordEM2's Avatar
Default k20a2 cams in k20a3?
can the cams in the k20a2 fit in the k20a3?
if so wouldnt it be better to buy an a3 and put a2 cams in the engine than to just buy the a2 and spend an extra 4-5g's?
Old May 8, 2007 | 07:16 AM
fventura03's Avatar
a k20a2 is not 4-5k more then a k20a3. if you search k20a.org you can find the thread that inlinepro made, they put k20a2 cams on a k20a3 and did 199whp.
Old May 8, 2007 | 09:58 AM
Rishelle's Avatar
Default Re: (fventura03)
thanks.
do you mind posting up the URL?
Old May 8, 2007 | 10:32 AM
fventura03's Avatar
yeah, i do.
Old May 8, 2007 | 10:33 AM
fventura03's Avatar
sikes:
http://www.k20a.org/forum/show...99whp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeremyinlinepro &raquo;</TD></TR><TR><TD CLASS="quote">Here is the how I got the K20a2 cams to work on the K20a3 head. You need the K20a2 cams (or type-r, tsx, crower...), K20a2 rockers and pins, and k20a2 rocker shafts. The pins in this picture are how they come in the A2 head
You have to switch the pins in the left and middle rocker like this picture
This locks the left and middle rocker together so that the middle rocker will not bounce around due to the cylinder head not having the lost motion spring.
This makes the left valve always ride on the vtec lobe and the right valve rides on the non-vtec lobe. When vtec is engaged by the solenoid it locks all three rockers together the same way the factory does and you have a regular working vtec.</TD></TR></TABLE>
Old May 8, 2007 | 10:40 AM
Rishelle's Avatar
Default Re: k20a2 cams in k20a3? (MikeJdmEm2)
thanks for the post, im just looking at both engines (like everyone else) and trying to find out what would be best to buy.
Old May 8, 2007 | 10:49 AM
fventura03's Avatar
K20a2 obviously . but i can understand money being tight. go with a k24a1 then slap a k20a2 head on it later on.
Old May 8, 2007 | 10:52 AM
Rishelle's Avatar
whats the prices on the k24a1's? and a k20a2 head shouldnt be that much right...
Old May 8, 2007 | 10:54 AM
fventura03's Avatar
K24A1's go for anywhere around $1200-1500 for the longblock, the k20a2 head is $1k. this combo provides very nice numbers, around 210-230whp depending i/h/e and other stuff.
Old May 8, 2007 | 10:57 AM
Rishelle's Avatar
wow... those are some pretty good numbers...thanks for the info... ill research on this some more.. thanks again dude
Old May 8, 2007 | 11:04 AM
fventura03's Avatar
no problem, check out k20a.org for EVERYTHING, it's the best place for information on any setup you want to do. look at what other people have done to get an idea of what you want to do.
Old May 8, 2007 | 06:05 PM
gsr x civic's Avatar
i got a2 cams for sale if you're interested.
https://honda-tech.com/zerothread?id=1966229
LMK
Old May 8, 2007 | 08:40 PM
bravo831's Avatar
Default Re: (gsr x civic)
i think you need a2 cams and crank
Old May 9, 2007 | 01:12 AM
i-VTEC_DOHC's Avatar
continuing from that.. climate and sea level play a factor too
Murk 'EM
Sep 4, 2007 10:32 PM
davidluko
19
Dec 13, 2006 10:32 PM
chasedatteg
Apr 15, 2005 05:44 PM
.nate
Mar 31, 2004 02:09 PM
bigplansnocar
Sep 26, 2003 08:12 AM
