intake manifold swap problems
Old May 8, 2007 | 07:00 AM
JUN.'s Avatar
Default intake manifold swap problems
I did a d16z6 IM with an LS TB swap on a d16y7 engine for my crx.......... The crx runned great with the stock manifold before the swap....
The car bogs some times and I there is a vacuum problem since it idles around 2000 rpms. I threw water with soap into the manifold where the IM gasket is, and the car bogs more....
some info:
1) I re-tightened the IM screws, but its the same...
2) Throttle body is all the way closed
3) idle screw is stuck
4) used a new crx 1.5L intake manifold gasket
5) there is a platform on the bottom of the intake manifold that matched the d16a6 manifold but the bolts dont match the d16z6 manifold
any recommendations ?
Modified by JUN. at 11:14 AM 5/8/2007
Old May 8, 2007 | 07:15 AM
JOE BD-0's Avatar
Default Re: intake manifold swap problems (JUN.)
just wondering, did you tighten the intake manifold per "the pattern"? kinda like the head gasket, where you start in the middle and work your way to the outside with the proper amount of torque in "steps"........just an idea
also, did you prepare (clean real good) the surface for the new gasket?
good luck.........
Old May 8, 2007 | 07:26 AM
JUN.'s Avatar
Default Re: intake manifold swap problems (JOE BD-0)
I did start from the middle,
I also cleaned and removed the old im gasket
Old May 8, 2007 | 07:32 AM
ef-hatchcrap's Avatar
check your tps sensor
Old May 8, 2007 | 10:08 AM
JUN.'s Avatar
Default Re: intake manifold swap problems (ef-hatchcrap)
I just bought an oem IM gasket at my local honda parts store....
well see...
Old May 8, 2007 | 10:11 AM
89efDUSTY's Avatar
I still don't get why people throw water and soap on the IM? ...also check your map & TPS
Old May 8, 2007 | 10:58 AM
h8tred's Avatar
From: Commonwealth my ass This is the communist state, VA, USA
Default Re: intake manifold swap problems (89efDUSTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote">I still don't get why people throw water and soap on the IM? ...also check your map & TPS</TD></TR></TABLE>
The same reason they say runned and not ran lol. It's just a common misconception. You use soapy water to find air pressing out (for example, a tire), and on an engine, you use carb cleaner or the like to check for vacuum leaks. The idea being that if you hit a spot that is leaking, it will rev a little higher as it sucks the highly flammable spray into the intake. Now, you have to use common sense as spraying things that are caustic on rubber will leave you with more leaks than when you started.
My opinion is you have an intake gasket leak. You may have gouged the surface, and there are two way to fix it. The right way: Take the head off, take it apart, and have all the mating surface machined. The wrong way (See bandaid fix): Use RTV sealant like any number of shady back yard know it all rednecks that like to make things worse than they were when they started working in it.
Just my two cents worth of soapbox preaching...
Old May 8, 2007 | 03:09 PM
JUN.'s Avatar
Default Re: intake manifold swap problems (h8tred)
Well it turn out to be the IM gasket of course.....
I removed the aftermarket one, cleaned everything, and used the OEM IM gasket..... no more leaks/coolant burns and car runs fine now....
I am not going to use any aftermarket gasket from now on .... my car was running like shitt and smoking coolan too.. =O
I learned the hard way
Old May 8, 2007 | 03:11 PM
JUN.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h8tred &raquo;</TD></TR><TR><TD CLASS="quote">
Just my two cents worth of soapbox preaching...</TD></TR></TABLE>
thanks for the advice..... But I guess the head or IM didnt warp
Old May 8, 2007 | 03:29 PM
89efDUSTY's Avatar
Just my two cents worth of soapbox preaching...</TD></TR></TABLE> gotcha...i just always thought soap and water were bad for the block...but never thought about it that way...good stuff, thats been one of the best thoughts in a while...if i could 10%+ for you sir
Severo Coronado
Mar 18, 2016 12:42 AM
CountDracura
Mar 24, 2009 12:56 PM
Honda4lyf
Aug 16, 2007 02:28 PM
99GSRTurbo
Jan 2, 2007 04:17 PM
RACEPAK
Nov 11, 2004 08:38 AM
