Bring her out of storage...
Old May 8, 2007 | 06:05 AM
g2tegsown's Avatar
Default Bring her out of storage...
My biggest concern is the engines lubrication, I plan on doing an fresh oil change (Any oil suggestions? I was thinking Mobil 1) before starting the car, will that be enough lubrication to to start her safely? I also plan on putting some new NGK Iridium IX plugs in as well.
Any other tips for starting her up?
Modified by g2tegsown at 10:16 AM 5/8/2007
Old May 8, 2007 | 06:18 AM
driveahonda's Avatar
Take out all you spark plugs ans spray wd40 into each cylinder.
Make sure you have decent oil in there... or just do an oil change.
Crank the engine with the plugs or plug wires out to lubricate everything.
Then you are good to go, common sense stuff really.
Old May 8, 2007 | 07:05 AM
g2tegsown's Avatar
Default Re: (driveahonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by driveahonda &raquo;</TD></TR><TR><TD CLASS="quote">Crank the engine with the plugs or plug wires out to lubricate everything.</TD></TR></TABLE>
How many times should I crank the engine before giving it some spark? Also I have heard you should pull the fuel injectors plugs as well, is that a good idea?
Old May 8, 2007 | 07:08 AM
Just crank it for a few seconds, not sure if there is an exact amount of time required.
Old May 8, 2007 | 09:35 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: Bring her out of storage... (g2tegsown)
Remove the spark plugs and drop a few drops of oil in each cylinder. Change the oil. Unplug the fuel pump and crank the engine until the oil light goes out.
Reinstall the spark plugs, reconnect the fuel pump and start the engine.
Old May 10, 2007 | 04:32 AM
g2tegsown's Avatar
Should I expect to see some smoke from my exhaust since we are putting some oil in the cumbustion chamber? Or will it drain back into the pan bytime we finish the oil change?
Old May 10, 2007 | 05:05 AM
it will smoke until it is all burned off
tim0na168
Jan 20, 2013 06:47 PM
sedlmeier101
Sep 4, 2007 09:15 AM
Midori Green
15
May 25, 2007 12:39 PM
sleepy_hatch
Apr 13, 2005 03:24 PM
Stryker908
Nov 11, 2002 02:52 AM
