Alternator problem or bad ground?
Old May 8, 2007 | 02:08 AM
EG6R's Avatar
Default Alternator problem or bad ground?
My battery gets drained after an hour of driving. The motor doesnt completely die while running but my a/c compressor shuts off(and doesnt go back on), the speedo needle starts jumping and my panel lights dim. When i get home i check the battery and see that it needs to be charged.
The battery does not get drained as long as i dont start/use the car.
Alternator problem or bad ground? What could it be?
Old May 8, 2007 | 03:53 AM
blackKready's Avatar
Default Re: Alternator problem or bad ground? (EG6R)
sounds like a bad alternator to me. does your battery light come on the dash with car running? could be bad grounds if it doesnt.
Old May 8, 2007 | 03:57 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
why don't you check the alternator and see if its charging the battery or not. The problem you listed is pointing in that direction. Its up to you to test it. Pull the positive clamp pf the battery while the car is started. If it dies right away its the alternator. Hold a dvm meter to check the output of the alternator. If its under 13 volts Replace it or go have it tested. Also make sure the belt is on tight.
Old May 8, 2007 | 05:52 PM
EG6R's Avatar
Default Re: Alternator problem or bad ground? (blackKready)
I havent had the time to take the alternator tested.
The battery light does not come on.
The car does not die if i pull out the battery clamp.
Old May 8, 2007 | 06:31 PM
first not all the time is the battery light going to come on if the alternator is dead. Do you have a digital volt meter? Can you unplug it and find out how much voltage it is putting out.
Old May 8, 2007 | 08:33 PM
aznguy0087's Avatar
Default Re: Alternator problem or bad ground? (wrx-killer-Sti eater)
alternator!!!, sounds like it, dude trust me man i had the same problem for like a month long went thought like 2 battery and 2 diff. alternator, all cause of honda giving me the wrong belt!!!
Old May 8, 2007 | 08:47 PM
FastLife617's Avatar
Default Re: Alternator problem or bad ground? (aznguy0087)
Yeah it sounds like bad alternator
Old May 10, 2007 | 12:17 AM
EG6R's Avatar
Default Re: Alternator problem or bad ground? (FastLife617)
I think its fixed.
I was checking the alternator and noticed that the ground was not bolted down tight. I tightened it and started the car to let it idle for a few mins with all accessories on. I tested to see if the battery was drained and it wasnt, which would have before.
I dont have a volt meter to check my alt so im using my battery charger to confirm.
I hope this fixes it but Lets see once i start using the car again.
Old May 10, 2007 | 06:43 AM
EG6R's Avatar
Ran the car for around an hour and the battery is keeping its charge
But my speedo needle still keeps on jumping
Old May 10, 2007 | 01:57 PM
check and make sure your main harness ground is clean and tight on the thermostat housing. or wherever it may be now , lol.
88 EF Hatch
Sep 17, 2009 07:29 AM
raidacaipo
10
Jul 29, 2008 01:13 AM
hondastrtracr
16
Jan 27, 2008 09:16 PM
deeice30
Dec 13, 2005 11:37 AM
EG6[B16A1]
Jun 28, 2003 09:03 AM
