question about my 89 si?
Old May 8, 2007 | 12:57 AM
civicgen3's Avatar
Default question about my 89 si?
i really new to this site, ive been to a site like this one, but all ive been geting is mix answer on my questions. i just did to a b18a1 swap. my self. wasn't as hard as i thought it would be, but all i do is work on hondas. i love the power that i got from the swap. its great. i didnt think i would get as much as i did.
but now i want a little more. i want to try and keep it old skool, and not use the vtec motors, at least for right now. im wanting to put a turbo on the car.
that where my i need help. i know lots about working on motors, but nothing about what turbo and ect. what i want to know is what do i need to do to not blow the car up. i want to try and get 10-15 psi out of it, but i dont want to blow the motor up, if i have to rebuild the motor so i dont thats fine but i need to know what type of part to get. here a list of what i need help on knowing.
1 which turbo,
2 fuel/ if anything and everything,
3 besides P&P what needs to be done on the head
4 r there any interal part the need to be done
if there anything else i may need to know let me know, i really need to find out everything i can about turboing this motor.
Old May 8, 2007 | 01:05 AM
Redline130's Avatar
Default Re: question about my 89 si? (civicgen3)
You should check out the forced induction section of this site. There is tons of helpful information that will get started on turbocharging your motor.
Old May 8, 2007 | 01:23 AM
civicgen3's Avatar
Default Re: question about my 89 si? (Redline130)
really ok ill check it out. is it a good idea tho to go turbo with my stock motor?
Old May 8, 2007 | 11:26 AM
civicgen3's Avatar
Old May 8, 2007 | 11:50 AM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgen3 &raquo;</TD></TR><TR><TD CLASS="quote">really ok ill check it out. is it a good idea tho to go turbo with my stock motor?
</TD></TR></TABLE> its all about the tuning and the maintence. Any motor can be boosted, but to keep it maintained is the big factor, also depends on duration / stress put on the motor. Read the Forced Induction Forum Faq and if you are serious about boosting read Maximum boost by Corky Bell, it teaches you stuff you dont find on HT
Old May 8, 2007 | 12:17 PM
wiZCo's Avatar
Stouts 'n' Scotch
Also may want to check out http://www.homemadeturbo.com
Old May 8, 2007 | 12:24 PM
Creator's Avatar
One weak spot in the LS motor is the rod bolts....switch em out with ARP, not much info but it's a start
JayCintronsEJ1
Feb 28, 2008 10:45 AM
jdmcivicsi522
Apr 18, 2006 10:26 AM
Racersky
Nov 2, 2005 08:26 AM
gumbybum
Mar 3, 2003 09:45 PM
CRX-TurboMan2
10
Aug 1, 2002 09:21 PM
