Si Suspension Revamp the HF
Over the years after the motor swap, me being a struggling college kid couldn't afford to put the adequate suspension i wanted on the car. So i've been using the stock hf suspension. My question is not will the Si fit the HF, this has already been confirmed with the Search button. However my question, the standards for the SI suspension (made for heavier 1.6l) motor, will this help fix the camber issue with the additional weight the B16a over the D series. Basically, I'm not looking for top of the line but the Si suspension seems to suit alot of people quite well and i like the way it rides. This upgrade to Si will this back off some of the weight pusing down on the Hub and the Camber issue? That's all. Thank you in advance.
hf stuff sucks si is better but I dunno if its worth the time and money to change it to more used stuff I would do it if you have no other option and you are buying tires all the time due to your camber issue
yeah, the hf blows on certain things, but you can't beat the weight/power ratio. My question still stands though will the stronger thicker suspension system bring the camber back to normal to compensate for the extra weight of the motor on the front end? Does someone have experience with this? Thanks
EK FLY
Oct 8, 2005 07:36 AM
gsr355
Mar 20, 2002 04:01 PM
