Random miss. Need Help
97 h22a. It has a random miss in it. Doesn't matter if its at idle or under a load. I've done alot of work on the car since i got it a couple of months ago. Plugs, wires, dist cap and rotor button. Had a blown intake gasket, exhaust manifold gasket, fixed them both and did a timing job. Replaced a bad tps and knock sensor. The car finally does good but still has a miss in it. I did a compression check and everything looks ok, so i'm at a loss. Any suggestions or help would be greatly appreciated. BTW no cel light.
jayc6677
Dec 26, 2007 07:28 AM
97civicDX-R
May 17, 2007 05:23 PM
