do i need new doors?
ok well i have manual doors on my car BUT the little metal piece that is used to roll up the window is STRIPPED!! so can i some how get the window roller on the door so it'd work or do i need to get new doors??
i would think its part of the regulator, but im not 100% sure on it....check this out
http://www.hondaautomotivepart...INDOW
you dont need new doors, ive replaces many of these fairly easy, will require to take out the glass, but shouldnt take u more than 30 mins per side
if i remember correctly all u need is a screwdriver phillips and maybe a flathead.
and like a 10mm socket or 12mm
ok so just this piece right here?
and also will the one from the EF civics work?? (i drive a 95) cuz i pulled one today at U-PULL-IT and it seemed to match up ok
KyleVA
Jun 9, 2009 09:54 AM
fs
Mar 26, 2004 08:50 AM
