USDM H22A4 to JDM H22A Swap - Help
Old May 7, 2007 | 09:00 PM
ethereal2pt2's Avatar
Default USDM H22A4 to JDM H22A Swap - Help
okay i'm swapping out my h22a4 w/ a jdm h22a. i got the motor out and everything. the problem is that the wire harness that came w/ it is butchered. so i tried to use the usdm wire harness on the h22a. i realized that some of the plugs are different between the usdm and jdm. i asked 98vtec if using the usdm harness was possible and he said i just needed to swap the intake manifolds. on further inspection, i realized the dizzy plugs [one of two] don't match up. and a few other ones. idno what they're called so i'll let my pictures do the talking. any thoughts are greatly appreciated.
sorry i forgot the camera was set to blk&wht. usdm then jdm respectively.
what plug is that for?
the left of the two dizzy plugs do not match up.
the plug for the alt don't match so i swapped them.
the p/s pump pipe didn't match so i swapped them too.
anyone know what that plug is for?
on the h22a, it has the two pipe stuff on the vss but the h22a4 doesn't. anyone know what they are? if i need theM? if i can just loop them together?
i swapped the ac compressor too cuz they chopped up the pipes for them.
and the motors in question
after the swap i will be selling my h22a4 piece by piece. i know this is the wrong section but anyone interested gimme a pm w/ a reasonable price. everything goes minus a few valves, they're bent.
Modified by _BB6 at 10:10 PM 5/7/2007
Modified by _BB6 at 10:13 PM 5/7/2007
Modified by _BB6 at 10:17 PM 5/7/2007
Modified by _BB6 at 10:20 PM 5/7/2007
Modified by _BB6 at 10:26 PM 5/7/2007
Old May 7, 2007 | 09:41 PM
98vtec's Avatar
moderator emeritus
Default Re: USDM H22A4 to JDM H22A Swap - Help (_BB6)
dude i figured you had read around on putting this engine in our BB6's. You need to swap the following things from your h22a4 onto the h22a:
alternator and bracket
power steering and bracket
ac compressor and bracket
lower timing cover
complete intake manifold (injectors, fuel rail...etc)
half shaft / intermediate shaft
distributor and coil
the outside of your engine is essentially going to be all off the a4
Old May 7, 2007 | 10:41 PM
Default Re: USDM H22A4 to JDM H22A Swap - Help (98vtec)
i did search but a lot of the jdm h22a swaps were for the 4gen and the ones one the 5gen didn't really help much unless im completely blind and i missed something. but thanks a lot. i was starting to fear the worst.
Old May 7, 2007 | 11:33 PM
what about the vss on the jdm h22a? it has those two pipes? and why would i need to swap the half shaft/intermediate shaft? can't i just hook them up from the cv joint?
Old May 7, 2007 | 11:43 PM
Rosko's Avatar
you can loop those lines for the vss. I believe they had something to do with the power steering system on a 4th gen.
Old May 7, 2007 | 11:46 PM
Rosko's Avatar
Default Re: USDM H22A4 to JDM H22A Swap - Help (Rosko)
you also need to swap oil pumps if you are keeping the h22a4 distributor, otherwise you can use the jdm distributor and you'll have to do a bunch of rewiring.
besides that do what Blake said
Old May 7, 2007 | 11:56 PM
thanks for the help guys. really appreciate it.
Old May 8, 2007 | 03:07 AM
Mydogisgone's Avatar
that's what we call ODB1 versus ODB2
Old May 8, 2007 | 07:16 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote">you also need to swap oil pumps if you are keeping the h22a4 distributor, otherwise you can use the jdm distributor and you'll have to do a bunch of rewiring.
besides that do what Blake said </TD></TR></TABLE>
oh yea! cant believe i forgot that, lol.
Old May 8, 2007 | 08:30 AM
aren't the half shaft/intermediate shaft the same for the jdm and usdm? wish i could compare them w/ the jdm one but the supplier chopped those suckers in half. damn i ordered all the parts required for the startup warranty last night.. came out to be $332
Old May 19, 2007 | 04:55 AM
alright so my friend henry and i have finally completed the swap. replaced the h22a4 w/ the jdm h22a along w/ complimentary a4 parts to supplement the usdm wire harness. got everything back together but the moment we start up the car this is what happens. take a look. any suggestions are greatly appreciated.
http://home.comcast.net/~mikelee22/CIMG5725.AVI
the motor will immediately die upon starting the car. the second-third time we start the car in the video it lasts the longest but that parade didn't last long.
Old May 19, 2007 | 12:49 PM
anyone?
Old May 19, 2007 | 02:34 PM
preludepower420's Avatar
Got Spark?
Old May 19, 2007 | 07:10 PM
flyrod's Avatar
Default Re: (preludepower420)
Getting any ECU codes? The CEL should come on then go back off when you turn the ignition on. If it never comes on, check your grounds. Next check the basic fuel/spark/compression/timing stuff, and go from there.
Btw, why the swap? Did the A4 die?
Old May 20, 2007 | 08:44 AM
Default Re: (flyrod)
yeah i just rented a obd2 scanner yesterday. checked the code and it came up as P0335. i believe that's the crank shaft position sensor. i'm not sure why this is the problem cuz my buddy and i swapped the whole pump w/ the ckps just because of that. and the reason for the swap was because the a4 had 173k miles on it and some of the valves are bent. it's a long story but that's how it is. any thoughts on that? thanks.
Old Jun 26, 2007 | 09:11 AM
dimenzi0ns's Avatar
Default Re: (_darkrequiem.)
My USDM h22a4 just died on me. I am about to order a JDM H22a and undergo this swap. Did you ever get your issues figured out? and should I undergo this swap?
Old Jun 26, 2007 | 05:36 PM
HenryTypeS's Avatar
Default Re: (dimenzi0ns)
if you have some car experience. at least one friend to help you. and a helms. then by all means, go for it. we got it finished in about a month but thats with ALOT of slacking.
Old Jun 26, 2007 | 06:45 PM
jaskuloski97sh's Avatar
Default Re: (HenryTypeS)
Hey man im doin the same swap and this should solve it as long as you havnt done it yet otherwise i'd say check if your dizzy is any good or plugs nd wires. Theres a crankshaft gear thats in the area of the oil pump. you need to swap it from your old motor. this will give your crank sensor a way to read wen your piston hits top dead center. let me know how it goes.
Old Jun 27, 2007 | 03:34 PM
MileHigh's Avatar
how much does the swap cost you
for parts?
any labor?
shipping?
thx
Old Jun 27, 2007 | 04:10 PM
vietluder2k1's Avatar
you swapped the oil pump housing right? on the oil pump housing, it should have the tdc and ckp sensor. maybe your ckp sensor was damaged when you swapped it. you should be able to use your old vss instead of just plugging up the holes. im having a shop do my swap right now, so i guess ill be running into the problems soon.
Old Jun 27, 2007 | 07:01 PM
91preyludesi's Avatar
Default Re: USDM H22A4 to JDM H22A Swap - Help (_darkrequiem.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _darkrequiem. &raquo;</TD></TR><TR><TD CLASS="quote">what about the vss on the jdm h22a? it has those two pipes? and why would i need to swap the half shaft/intermediate shaft? can't i just hook them up from the cv joint?</TD></TR></TABLE>
also curious why you need half/intermediate shaft. i am doing this swap shortly as well and would like to know
Old Jun 27, 2007 | 08:49 PM
Default Re: USDM H22A4 to JDM H22A Swap - Help (91preyludesi)
You need the intermediate shaft because your driver side axle used to plug into the ATTS sysem that is if you had an SH model prelude so if you dont you already have it otherwise the intermediate shaft takes the place of ATTS. Luckely your axles will fit and you wont have to change them.
Old Jun 27, 2007 | 09:05 PM
my9thtry's Avatar
Default Re: USDM H22A4 to JDM H22A Swap - Help (jaskuloski97sh)
just double checking, you changed the oil pump from the h22a4 right??
Old Jul 20, 2007 | 02:07 PM
DiMeNSi0N's Avatar
I've done the swap but when i start the engine. It dies after a minute. I am getting a P0335 crank position sensor error code. I swapped the oil pump and housing so i could mount the sensor and I replaced the gear so it could read. Any other suggestions?
Old Jul 20, 2007 | 05:58 PM
DiMeNSi0N's Avatar
Default Re: (DiMeNSi0N)
Ok... Gotten past the crank sensor issue. Turns out that there is TWO gears that need to be swapped because each sensor reads its own gear. Problem I am having now is that I have NO oil pressure. Any suggestions?
MKCSRet
Aug 7, 2014 06:40 AM
tegman85
May 23, 2007 05:59 PM
951dc5
May 17, 2006 02:25 PM
hungy
Sep 8, 2003 07:26 AM
JdmCIVIC853
Feb 9, 2003 03:32 PM
