How to repaint your rims the right way and get a super clean new shine !!
Old May 7, 2007 | 08:04 PM
JDM TR Civic's Avatar
Default How to repaint your rims the right way and get a super clean new shine !!
Hey guys, So I thought i would take the time to take some pics and do a little write-up along with my last project. I took the initiative to fix the infamous rota paint and refinish them them the RIGHT way. As you will see in the following pics and descriptions I'll take you from A-Z with pics to show you how i did it, also, If you ever have any questions dealing with my project feel free to PM me or Email me at webs103086@yahoo.com. On with the write up!!
To start lets get the good stuff you are gonna need. Pictured below is the Aircraft Remover i used to strip the old paint off of the rims (Works perfect). Also pictured is the High heat engine primer that i used as my rims (gives a very durable base that will withstand heat, chipping, and flaking. Then pictured is the base coat (you will use whatever color you want) The dupli-color paint is well known for its extreme durability and adhering qualities, And along with the Dupli-color clear coat the finish you will get an extremely durable, shiny, and appealing finish that will outlast even the toughest daily driving.
**clean your rims very good, inside and out. Super strength Mean Green works perfect**
Next you will need to Mask off your tires if you are doing this job as I did with the tires already mounted on the rim. IF you don't have your tires mounted no worries! I used duck tape to tuck behind the lip of the rim ( sticks better to clean rubber than masking tape). Then use masking tape to tape either plastic or paper around your wheel onto the ducktape. Now you will be at the stage pictured below.
Now you will coat down all the rims, inside and out with the aircraft remover. I used a can per rim, more is better!! Spray the remover covering the entire surface, including all the nooks and crannies. Then let them sit for about 10-15 min. Once the aircraft remover goes to work you will begin to see what is pictured below. This tells you that the remover is working as you can see the enamle bubbling up. **Works best in mild heat conditions. (55-75 degrees) w/ humidity below 60%**
Once you have waited 10-15min and the enamel has bubbled or softened, use either a pressure washer, or a hose with the harshest direct stream possible to blast all the aircraft remover and softened enamel off the rims. If all the enamel comes off, great, if not, repeat with the aircraft remover and spraying. Once you get 99% of the enamle off they should appear as the ones below.
Next you will need to scuff and prepare your rims for the primer. You can use the Red and/or Green 3M scuff pads (available at most auto part and/or paint supply stores). Along with the scuff pads you will need to use a little bit of elbow grease. Once you have them scuffed it is time to wipe them down, use some type of cleaner like Naptha or Acetone to clean the rims down and then thouroughly wipe them with a dry rag afterwards. Spen time and make sure they are thoroughly clean and wiped. If all goes well and you are careful with applying the primer, your outcome should look something like what is pictured below.
After you spray the primer you will want to let it sit for about 2hrs to dry thouroughly. Once it is dry it is time to spray your base coat (color coat) after applying 2light coats and 1medium-wet coat, you will need to let it dry for about an hour before applying the clear. before the clear your rims will be shiny and clean looking inside and out as pictured below.
Once you have waited an hour after your last base coat, it is time for clear, the clear will be applied in a manner different than that of the base coat. As you spray it, you will spray in a parallel manner, meaning do not spray directly at the rim, spray parallel to it and allow it to "fall" onto the surface. This technique will give you a more uniform or "glass like" appearance. Apply about 2-3 coats of clear and WA-LA you are done painting. Now you just wait about 3hrs or possibly the next day and unmask them. **Keep in mind that alothough the paint is dry to touch and handle in 3hrs. it takes nearly 7 days to fully harden and cure, which will protect against damage from tightening lug nuts and chips while driving. That being said. Here are the pics of the findal outcome.
Well, I hope some of you will enjoy this write-up and find it informative and/or usefull. Good luck to you DIY'ers out there and have fun with your shiny new shoes. Again, If you have any question and or comments please leave a post, PM me, or email me.
Modified by JDM TR Civic at 12:01 AM 5/8/2007
Old May 7, 2007 | 08:23 PM
Penger19's Avatar
Default Re: How to repaint your rims the right way and get a super clean new shine !! (JDM TR Civic)
Modified by Penger19 at 9:09 AM 5/10/2007
Old May 7, 2007 | 08:25 PM
faster Type R's Avatar
Default Re: How to repaint your rims the right way and get a super clean new shine !! (Penger19)
nice write up...looks like you did a good job on your wheels
Modified by faster Type R at 10:25 PM 5/7/2007
Old May 7, 2007 | 08:33 PM
kon's Avatar
kon
Default Re: How to repaint your rims the right way and get a super clean new shine !! (faster Type R)
Modified by kon at 10:15 PM 5/7/2007
Old May 7, 2007 | 08:35 PM
eg9beast's Avatar
Tuna-Killer
i think he wants people to im him or email him , no ?
Old May 7, 2007 | 08:39 PM
Arsenal's Avatar
Default Re: How to repaint your rims the right way and get a super clean new shine !! (eg9beast)
Very nice job
Modified by Arsenal at 6:12 AM 5/8/2007
Old May 7, 2007 | 08:51 PM
Genuine Rolla's Avatar
VERY NICE WRITE UP..!! book marked...!
Modified by Genuine Rolla at 10:07 PM 5/7/2007
Old May 7, 2007 | 09:07 PM
IntegraDriver's Avatar
Default Re: (Genuine Rolla)
Full write-up is now posted, so on with the informative and postive comments.
Old May 7, 2007 | 09:10 PM
imeonic's Avatar
nice write up
Old May 7, 2007 | 09:14 PM
hpi247's Avatar
Default Re: (JDM TR Civic)
wow they look really good, nice job . how much did it all cost you? any pics on the car yet?
Old May 7, 2007 | 09:23 PM
mormonboy's Avatar
Default Re: (hpi247)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hpi247 &raquo;</TD></TR><TR><TD CLASS="quote"> how much did it all cost you? </TD></TR></TABLE>
I don't have any pics of the car yet, cause i just finished the job on Sun 5/6/07 and i want them to be totally cured before i bolt them on and drive them. to having a daily driver besides my hatch. They will be goin on my hatch in my sig.
Old May 7, 2007 | 09:25 PM
NMZ's Avatar
NMZ
what a waste of those bronze wheels
Old May 7, 2007 | 09:26 PM
Default Re: (mormonboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hpi247 &raquo;</TD></TR><TR><TD CLASS="quote">wow they look really good, nice job . how much did it all cost you? any pics on the car yet?</TD></TR></TABLE>
I would say all in all it costed me some where around $60 for all the supplies needed for the entire project.
Old May 7, 2007 | 09:27 PM
mormonboy's Avatar
looks way better in white!
white is the new bronze f00!
Old May 7, 2007 | 09:28 PM
Default Re: (NMZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NMZ &raquo;</TD></TR><TR><TD CLASS="quote">what a waste of those bronze wheels </TD></TR></TABLE>
You didn't get to see how the paint was peeling off of them, otherwise I agree. It would be a waste of perfect bronze rotas.
Old May 7, 2007 | 09:31 PM
JDM-EJ1's Avatar
Wow, that turned out really good.
Old May 7, 2007 | 09:32 PM
Civic DX 4dr's Avatar
damn that came out good
Old May 7, 2007 | 09:40 PM
beoy9's Avatar
Sweet man, those rims look lots better! Think it will work on my circuit 8's?
haha j/k but I think I'll give it a try... once my 50 other projects are done. =]
Nice write up man.
Old May 7, 2007 | 09:41 PM
teamsol's Avatar
nice!!
Old May 7, 2007 | 09:44 PM
MasterShake's Avatar
great job
kptrulee's Avatar
Default Re: How to repaint your rims the right way and get a super clean new shine !! (teamsol)
GREAT write-up!!!
Old May 7, 2007 | 09:45 PM
Locc's Avatar
Default Re: (MasterShake)
turn out good
Old May 7, 2007 | 09:51 PM
SuperSonikBluEK's Avatar
Looks awsome! gud job!
