ned help with vtec wiring
Old May 7, 2007 | 06:36 PM
jdmhatch3's Avatar
Default ned help with vtec wiring
ok im down to one wire left to hook up and i need help. i have a 88 hatch with a mpfi wiring swap and a b16a obdo swap with a pr3 ecu. now i have a blue wire with a black stripe coming off the vtec silinoid. i cant find a blue wire with a black stripe anywhere else so does anyone know where to hook this up?
Old May 7, 2007 | 06:37 PM
Janos Lin's Avatar
Default Re: ned help with vtec wiring (jdmhatch3)
U gotta run that wire directly to the ECU since it's not present in the factory harness.
Check the FAQ, should have directions on which ECU pin you need to plug it into.
Janos
Old May 7, 2007 | 06:38 PM
enkeiteg's Avatar
a little rusty but here goes.
that goes to pin a8 on the white connector. you might need to pin in the ecu, as most swaps here didnt come with vtec until the delSLO. b5 is the pressure switch. and the ground of the pressure switch-find a descent ground.
KiDDD...
Mar 27, 2012 06:11 PM
fryman
Sep 24, 2008 10:07 AM
Jakester9500
12
Aug 8, 2007 05:25 AM
93(Civic)EG6
Aug 4, 2007 06:10 PM
ilovemyb16a
May 18, 2006 12:58 PM
