do you need this part in the throttle body ??
Old May 7, 2007 | 06:23 PM
JUN.'s Avatar
Default do you need this part in the throttle body ??
its the part between 15 and 3
i bought a TB and it doesnt have it
Old May 7, 2007 | 06:30 PM
JUN.'s Avatar
Default Re: do you need this part in the throttle body ?? (JUN.)
the real question is, can I use the TB without that thing.....
Looks like its just a device to keep the throttle open while idle...... But I was wondering that I could adjust the TB cable a little tighter and it will do the job ?
Old May 7, 2007 | 06:40 PM
Janos Lin's Avatar
U need it. Pulling the cable tighter isn't the best soultion since it also acts as a buffer to slow down the throttle closing so the engine doesn't choke and die.
Janos
Old May 7, 2007 | 06:52 PM
Crx Jimmy's Avatar
you dont need it it was only on the tb's for a couple years. all the new Tb's dont have it. I took mine off and it drives the same.
Old May 7, 2007 | 06:53 PM
Crx Jimmy's Avatar
Default Re: do you need this part in the throttle body ?? (Janos Lin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Janos Lin &raquo;</TD></TR><TR><TD CLASS="quote">U need it. Pulling the cable tighter isn't the best soultion since it also acts as a buffer to slow down the throttle closing so the engine doesn't choke and die.
also it wont choke and die. thats what the throttle adjustment screw is for
Old May 7, 2007 | 06:55 PM
W O T's Avatar
Default Re: do you need this part in the throttle body ?? (Crx Jimmy)
I dont have it on my car, originally came with it
Not needed
Old May 7, 2007 | 07:02 PM
dr_latino999's Avatar
Default Re: do you need this part in the throttle body ?? (W O T)
Isn't needed except for Auto's, and in later years the ECU's negated their existence.
Old May 8, 2007 | 06:58 AM
JUN.'s Avatar
Default Re: do you need this part in the throttle body ?? (dr_latino999)
sweet thanks
Old May 8, 2007 | 08:34 AM
djphonics's Avatar
Dashpot. Not needed. It slows the closing of the throttle when you are engine braking. Most likely an emissions thing.
Old May 8, 2007 | 08:43 AM
glagola1's Avatar
Holy crap! Is that why when you get off the throttle you can hear some combustion taking place in the exhaust for about 3 seconds?
Old May 8, 2007 | 09:37 AM
SIred91's Avatar
Rainman
Default Re: (glagola1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by glagola1 &raquo;</TD></TR><TR><TD CLASS="quote">Holy crap! Is that why when you get off the throttle you can hear some combustion taking place in the exhaust for about 3 seconds?</TD></TR></TABLE>
Buwhahahahaha.....
Old May 8, 2007 | 11:55 AM
LankorDie's Avatar
Loved
Community Favorite
Because we are on the subject, what does the little guy in between 18/20 do? Mine is all blocked off.
I have a crappy idle is why I ask.
Old May 8, 2007 | 11:57 AM
Default Re: do you need this part in the throttle body ?? (LankorDie)
The Fuel pressure regulator?
Old May 8, 2007 | 12:00 PM
LankorDie's Avatar
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">The Fuel pressure regulator?</TD></TR></TABLE>
Jesus wrong part!
It's on older B16's looks kinda like that, and is on the front of the intake manifold. I'll take a picture later to end the confusion.
Awful picture, but might give you a idea of what I'm talking about
Old May 8, 2007 | 12:05 PM
Bob_760's Avatar
I forget what those things are, but I'm pretty sure nothing needs to be hooked up to it, my B16A didnt have anything on em. It's something the DA Teg uses.
Old May 8, 2007 | 12:06 PM
Bob_760's Avatar
Default Re: do you need this part in the throttle body ?? (Bob_760)
Ur talkin about this right?
The thing that says UP on it?
Old May 8, 2007 | 12:13 PM
glagola1's Avatar
Default Re: (SIred91)
What's so funny?
Let me discribe the occurance a little more clearly. When I let off the throttle completely, the engine burbles and pops for about three seconds which to me would indicate that there is some amount of partial throttle being applied or atleast there is a small amount of fuel being burnt for a moment. After this three seconds the engine goes to straight engine braking and the burbling is absent.
I had always assumed this was a product of the ecu's control over the engine. It would be cool if I could simply disconnect this dashpot and have the engine go straight to braking like most cars do.
Old May 8, 2007 | 12:20 PM
LankorDie's Avatar
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob_760 &raquo;</TD></TR><TR><TD CLASS="quote">Ur talkin about this right?
Bingo, that is a much better picture! Thanks, so anyone with more info on that thing?
wade
Mar 18, 2009 01:14 PM
hamst3r3x
Dec 10, 2007 09:41 PM
supracrx
Jan 7, 2007 08:06 PM
damn_import_culture
Jul 13, 2006 08:06 AM
Cute EK
Nov 15, 2005 06:18 PM
