TDC on Crank Pulley keep jumping
Old May 7, 2007 | 05:31 PM
1990-hf's Avatar
Default TDC on Crank Pulley keep jumping
Got a D16Z6 motor and had the head re-surfaced with a new head gasket but the TDC on the Crank Pulley keeps on jumping. Using the Timing Gun, the TDC mark kept on jumping back and forth from the pointer on the timing belt cover. Plus the timing belt is slightly loose on one side. Could the tensioner cause the problem or does anybody know what would the problem be.
Thanks
Old May 7, 2007 | 05:55 PM
Janos Lin's Avatar
Default Re: TDC on Crank Pulley keep jumping (1990-hf)
Did you jumper the ingition timing connector?
Janos
Old May 7, 2007 | 06:00 PM
ChickenH's Avatar
is it missing really bad, dropping that cylinder? that makes it jump. it fires the plug wire every other time that piston comes up at the same time hopefully flashing the light. so if its not doing this somethings wrong or theres a bad connection. also it will try to move timing back inside the ecu if you dont jump the wire.
Modified by ChickenH at 6:37 AM 5/8/2007
Old May 7, 2007 | 06:01 PM
sporkcrx's Avatar
I've used cheap timing lights that have the mark jumping (inconsistent flashes from the timing light) If you know any mechanic buddies, try using a quality one if they have it.
90civic-ZC
Nov 23, 2011 02:36 PM
ApolloSpeed
May 1, 2005 08:31 AM
wantmorepower
Apr 15, 2003 08:07 PM
