Clicking noise when starting?
Old May 7, 2007 | 05:23 PM
5G_Vtec's Avatar
Default Clicking noise when starting?
I may have asked this question a while back. I searched for it also, but came up with nothing.
Anyways, I have a 95 Accord and when I go to start it it just clicks instead of starting. I usually have to turn the key 5+ times to get it started if it doesn't start the first time. Sometimes I end up flooding the enfine and have to wait a while before I can go back and try again. I just recently changed all 4 spark plugs, but did not get new spark plug wires. I think it could either be the spark plug wires, alternator, or starter. Has anyone else experienced this or have any advice of what it could be? I want to start with the cheaper things first because if it's just the wires, I'd rather spend $45-65 on wires where as spen $200 on a starter.
Thanks in advance!
Old May 7, 2007 | 05:35 PM
Patman's Avatar
low battery if when it finally cranks it cranks really slow or if its normal cranking, bye bye starter.
Old May 7, 2007 | 05:43 PM
5G_Vtec's Avatar
Default Re: (Patman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patman &raquo;</TD></TR><TR><TD CLASS="quote">low battery if when it finally cranks it cranks really slow or if its normal cranking, bye bye starter.</TD></TR></TABLE>
I just got a new battery. It's not a crank either, it's one click when i turn the key if it doesnt start up right away.
Old May 7, 2007 | 06:16 PM
hondadude's Avatar
Default Re: Clicking noise when starting? (5G_Vtec)
Why spend $200 for a starter when it's only the $20 contacts that are bad?
You pull the starter off and then the end cap, 2 nuts on either side and replace the contacts.
Most auto elec. shops will have contacts in stock for ND starters.
sjtran
Apr 6, 2021 07:48 AM
OMGFML
12
Aug 1, 2012 11:33 AM
91NSX
Aug 24, 2009 11:09 AM
po0tie
Feb 17, 2008 09:46 AM
ek4__
Oct 9, 2006 02:48 PM
